More Zen To Live By.
dlstewart01
> 1. Do not walk behind me, for I may not lead. Do not walk
> ahead of me, for I may not follow. Do not walk beside me
> either. Just pretty much leave me alone.
> 2. The journey of a thousand miles begins with a broken fan
> belt and leaky tire.
> 3. It's always darkest before dawn. So if you're
> going to steal your neighbor's newspaper, that's the
> time to do it.
> 4. Don't be irreplaceable. If you can't be
> replaced, you can't be promoted.
> 5. Always remember that you're unique. Just like
> everyone else.
> 6. Never test the depth of the water with both feet.
> 7. If you think nobody cares if you're alive, try
> missing a couple of car payments.
> 8. Before you criticize someone, you should walk a mile in
> their shoes. That way, when you criticize them, you're a
> mile away and you have their shoes.
> 9. If at first you don't succeed, skydiving is probably
> not for you.
> 10. Give a man a fish and he will eat for a day. Teach him
> how to fish, and he will sit in a boat and drink beer all
> day.
> 11. If you lend someone $20 and never see that person
> again, it was probably a wise investment.
> 12. If you tell the truth, you don't have to remember
> anything. This becomes more important as you get older…
> 13. Some days you're the dog; some days you're the
> hydrant.
> 14. Everyone seems normal until you get to know them.
> 15. There are two theories to arguing with women. Neither
> one works.
> 16. Generally speaking, you aren't learning much when
> your lips are moving.
> 17. Experience is something you don't get until just
> after you need it.
> 18. Never miss a good chance to shut up.
> 19. By the time your kids are fit to live with, they’re living with somebody else.
And last, but not least:
20. It’s probably not wise to take a sleeping pill and a
laxative on the same night.
An empty gun is a poorly balanced club.--unknown
"Government does not solve problems, it subsidizes them."--Ronald Reagan
Enjoy the day.
Yep :mad:
My Grandfather told me that 35 years ago. Great lesson.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
