Brake Lights Stay On - Need Suggestions
I came home today and when I turned off the truck. The brake controller lights started blinking and I heard a noise like a relay is going on and off. The noise stopped, but the brake lights on the truck are staying on. We haven't plugged in a trailer during the last 5 months.
I have disconnected the battery so it doesn't drain.
Any ideas of what to check?
Thanks.
Thanks.
Maybe try disconnecting the brake controller power? Maybe it's going nuts?
Yeah, check the plug and wires to it for a short that would be confusing the brake controller.
I assume you are talking about an add-on trailer brake controller which sits under your dash?
Is the clicking noise coming from this?
If yes, these have a manual switch on them to activate the trailer brakes only. When this switch is activated, it may send voltage back out to your brake pedal brake light switch to turn on the brake lights.
So there could be a problem with that manual switch or the electronics inside which is making this activate. One common problem with electronic things are "bugs"! Critters, spiders, etc. A bug may have crawled inside and is shorting out something.
I would try operating the manual switch a few times as this may clean out anything which may have crawled into the opening and is shorting the circuits. If that does not work, try blowing into any openings with compressed air.
If that does not work and you are comfortable taking electronic things apart, take the controller apart and clean out with compressed air.
Another thing to verify is if the controller is causing the problem... These usually have a plug on the back you can remove. Try unplugging it to see if the problem goes away and the problem is in fact the controller.
Or could also be an electronic problem with the controller and it would need to be fixed or repaired. Before doing that, check all wiring to be sure nothing is shorting. Best to use a multi-meter.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
