Rear Brakes 05 Silverado
wires57
New to this forum....Could you direct me to the procedure and or tool for removing the mounting hardware holding the rear brake shoes on a 05 Silverado? Thanks.
Welcome to the site.
Where are you from? .... and did just buy your 2005 and is it lifted at all.... just wondering :thumbs:
As far as the rear brakes are concerned, im not sure if there is a procedure outlined for it that you can read from. There are some special tools that make the job a lot easier but i've done countless drum brake setups (including 05 1500s) using vise grips and screw drivers.
Best thing to do is just take one piece off at a time and leave the other side of the axle in tact so you can reference it for re-assembly.
Some basic steps for dissassembly:
1) shorten adjuster as much as possible
2) remove springs
3) remove shoes
Assembly:
1) put some anti-seize on areas where shoes make contact with backing plate
2) clean threads of adjuster and put some anti-seize on them too
3) install shoes
4) install springs
5) put adjuster back in
I now have a drum brake installer/adjustment kit and the tools in there make this job a breeze!
