Front Swaybar For '74 C-10 2wd?
Hi-
I have to rebuild the front end on my 1974 Chevy C-10 2WD shortbed so that I can get a state vehicle inspection sticker. When the guy at PST asked what the diameter on the swaybar was, I went "DUH" since after all these years, I had no idea.
Cut to the chase: I went out and crawled under the truck and there is no sway bar and no evidence that there ever was one there. In my Chilton's, one of its "typical" illustrations shows that they were installed. I even looked under my '69 Impala to see about where Chevy attached the bushings to the frame and checked my truck again but could find nothing.
Does anybody know if these trucks had one? Would it be recommended to try to install one for better handling or better to leave well enough alone? Just for grins, it is an original 350 with a 2 barrel rochester and manual saginaw trans with 3.73 rears.
Thanks for reading my post,
Vinny
I have a '77 GMC 3/4t. and it definately has a sway bar. 1 1/8 dia. IIRC :smoker: and do help with the handling.
I did some searching in one of my manuals and found this...it was in my '67-'82 Haynes....hope it helps :lol:
Thanks for the help. Looks like those brackets that the sway bar bushings mount to are key to the success of this project. Unfortunately, they are not on my frame rails. I bought it about 19 years ago and have made no modifications. But who knows what went on prior to me having it.
Thanks again, Vinny
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
