I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of 2015 Sierra, to put into my 2016 Sierra WT (as base model as it gets).
On install, I noticed that I’m missing the plug in connector for the heated steering wheel to connect to that is commonly found behind the dash.
I put on an Add-A-Fuse at my heated steering wheel fuse location, which has voltage, and tied it to positive on my steering wheel. Took ground to ground and bobs your uncle… except no heating functionality.
is there something I’m missing?
Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
Not in my 2021. It's either on or off. There is no selecting front or rear. My scanner says something like implausible value for the rear monitor. I just disabled monitoring and keep driving it. There's physical metal squealer tabs on the pads for a reason. That's how people always knew when to change the brake pads or ignore them until the vehicle wouldn't stop anymore!
