Check Charging System Error
Paul58
I don't know if this is a coincidence or if it has to do with the BlueSTAR kit, but after I finished the installation and turned the truck on to test it, I had a "Check Charging System" message and the red Battery light is on. I tried to read the code with my ScanGuage, but it saays no code present. I also tried to use the ScanGuage to clear the code (according to the voltage guage, it putting out over 14 volts) but had no luck with that either. Any suggestions on how to clear this error? I really don't think there is anything wrong with the charging system being as all was okay prior to installing the BlueSTAR.
The BlueSTAR is working flawlessly, but you do have to remove the OnStar module to install it, whould removal of the OnStar module cause this error? Any suggestions on how to clear this code so I can see if it stays gone or comes back? Thanks...
I pulled out my OnStar module once and had no charging error issues. Try pulling the BlueStar module, if you have the dash all back together, it won't be fun, but that will test if the BlueStar module is the problem or not. If the message goes away, it may be suspect, if it does not go away, try plugging the OnStar module back in. If that's not it, someone else will need to start stepping you through diagnosis.
Checked this morning and it cleared itself! Thinking back, I think I had left the headlights on while I was testing and playing (without the engine running) and that may have caused it. All is back to normal now...
I don't know what triggers the check charging system message but it's possible that could have caused the issue.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
