New Problems
Went to the dealership for some work friday. truck has right frt lower ball joint loose, clunk in rear, oil leak around crank sensor, water leak on drivers door, window switch, and noise in transfer case when in four wheel drive. They replaced window switch. Ordered crank seal, weather spriping for drivers door, all new insulators for rear leaf springs, and new ball joint. The noise in in the transfer case is a bearing inside they think. They want me to drop it off for a few days to take apart and order parts. Truck has 21,000 miles on it. I will let you know how it goes.
Holy crap! I haven't had that many problems, COMBINED, in all the vehicles I've owned in my lifetime, and I'm an old retired coot!
good lord...either you beat the shit out of your vehicles or you got a lemon.
NO JOKE! I've not heard of anybody having a laundry list of issues on a GMT900. I know there have been isolated issues like anything else but WOW!
Hope you get it fixed soon!
Holy crap, that's more stuff than what's wrong with MY truck... :lol:
:wtf:
:lol: I hope you get every thing fixed.
Are you sure that's all? :lol:
I use bill mcbride chevy in plattsburg new york. Truck never been off road. Got to love the pot holes up here. They are going to call me when they get the parts. The dealer is the 50 miles away. Its about a hour away
  • 3 weeks later...
Well I picked up my truck last night. So far so good! I have not had a chance to test the four wheel drive to see if my noise is gone. They replaced the crank sensor, all new rear spring insulators, new door seal on outer edge, replaced my ball joint, and I had a leveling kit in. They found bearings bad in the transfer case, so they replaced them, and new seals.
  • 11 months later...
my name is john i own a 2006 silverado with noisey transfer case in 4 wheel drive i am on exstended warrenty now with 80,000 km on it the noise started 2000km ago and has got steadly worse,they are trying the old nothing wrong, this is normal trick but not accepting this awnswer,please let me know if after the repairs the noise is gone and what they did to get ride of it ,my email address is [email protected] as soon as you know this would be much appreciated! john.ps is your tcase push botton with auto 4x4.option.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
