F/s Nitto Terra Grapplers 285/65r18
I am looking to sell my Nitto Terra Grapplers. They are Load "E" rated and are a little heavy/overkill for my needs. I want to go with a lighter tire.
These tires have been rotated twice already and are wearing perfectly.
These tires were $225/each new.
$400 for the set.
Local sale only (I am in the East Metro/Twin Cities).
That's a bargain deal. I'm sure they will go away.
What is next?
Not sure yet. BFG A/T KO's if they are available in 18" with a load range C? Otherwise I am open to suggestions.
What is next?
Not sure about now but BFG 18s in 07 were all E rated. I had them (285-65-18) on my Titan and they were like carved out of stone.
What is next?
That's what I am afraid of. Oh well, I will find something.
What is next?
Get you some Vogues!
A little mustard and mayonnaise would look great on Ol' Greynus. :thumbs:
What is next?
Boggers! Do it!
I could be wrong, but I think you're going to have a hard time finding anything less than load range D unless you go down to 265/65-18s. I've looked into this a little bit myself, and it just seems that if you want "oversized" tires, you're looking at load range D and E.
I may just do that then. My Nittos weigh right around 60 lbs each.
These weigh 41 lbs each.
They would suit my needs fine without robbing so much power and efficiency. They are only 1" smaller in dia.
bfg doesn't have any tires in the 18" size that are not E rated.
Nittos TG you can get LT325/60/18 tire in D rating. It is a 33x12.5 tire.
Toyo AT's you can get a LT275/65/18 tire in load rating C which is a 32x11 tire
or they have P rated tires in size P265/70/18 which is a 32.6x10.7 size tire which is what you probably want. They are the same hieght as you have now but just a little narrower tire. And have the same thread pattern as the nittos
Thanks! I will look into both of those as well. But if nobody wants my Nittos, then this will all have to wait a few years until they are worn out.
No problem but someone should buy them because that is a steal of a price. You might want to consider shipping them.
I suppose I would ship them if the buyer wants to pay shipping cost, which I am sure would jack the price up quite a bit. No idea how much shipping these would cost?
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
