Lifting A Denali..
I've been thinking. I want to get a new truck, and I am torn between a Sierra SLT with the 6.2l and the Denali. Of course, I want to go with the Denali, as money isn't an issue. The only problem is, I like my trucks lifted, and large tires on them...
First off, the Denali is 2wd or AWD. I have to have AWD of the two, but will putting a lift and 35" mud tires on it cause any problems? i.e., hard steering, excessive tire wear, much lower gas mileage?
That would be my dream truck, but something tells me its not a good idea to put a 6" lift and 35's on a AWD truck... What do you think?
I'd think you'd be OK if it was strictly a pavement pounder. It you plan to do anything off-road with it, I'd get a true 4wd system. A Silverado LTZ with 4wd will have most of your comforts of a Denali, and be much more suitable for a lift and off-road use.
Edit: Sierra W/T and stick Denali badges on it.
Get the slt with the 6.2L & switchable 4wd , I believe the awd denali isnt really the truck for 4 wheelin.
Mine aint going wheelin any time .dont think thats what the AWD in this truck was designed for ? I was told its a viscous coupling & a 1 speed transfercase ,so no lo speed 4wd with this setup . just get the truck with the 6.2L & 4wd & all is good .I believe you can get a sierra or silverado with the 6.2 now.Just load it up with every option .
Actually, although I want this truck to have a lift and bigger tires, my final motive is NOT for it to be an "off road" truck. Yes, a few dirt roads here and a little low spot once in a while, but nothing trastic. This will be primarily a street truck. I have another truck that can be my "huntin" truck, for the off road chores.
How about bringing it down to a 4" lift and 33" tires? I also read on another thread that you couldn't lift Denali's.... something about stabilitrac or something? Then I saw two more threads were guys did lift their Denali's! Whats up with that? :D
It can be done... http://www.gm-trucks.com/forums/index.php?...ic=78720&hl=
I think I will just get a SLT with the 6.2 and true 4x4... lifting a Denali just seems to complicated! :D
I think that's a good choice. A lifted Denali just doesn't look right in my opinion.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
