89 K1500 Brake Code - Help
cameronc
I have a 89 K1500 pickup. On my way home from a fishig trip the other day my brake light came on. After i drove a few miles the light starting flashing. I unhooked the battery and it went out for a few days. On my way home from work yesterday it came on again doing the same thing. It flashes 9 times, then steady, then 9times, and repeats itself. I dont know if its a code 9 or 99. But i wasnt even aware that these older trucks even had brake codes. Can someone please help me with this crazy flashing brake light on my dash. HA HA. I have checked the fluid and plug-ins, doesnt seem to be anything wrong and the brake still work perfect. Thanks for your help.
Do you have anti-lock brakes?
And specifically do you have rear wheel only anti-lock brakes?
If yes, code 9 would be a problem with the speed signal to the anti-lock brakes (according to my 1992 factory service manual). Yours *could* be some other problem!
To find this problem the quickest, you would need a multimeter, know how to use a multimeter, and need a factory service manual for your year and model vehicle (get from dealer).
The factory service manual includes a wiring diagram of the anti-lock brake system, lists various anti-lock brake codes and what they mean, and gives detailed troubleshooting instructions for finding the exact problem.
Just like you need the right tools for automotive work, the factory service manual is another tool to help you diagnose the problem and give you instructions on fixing the problem.
I got the code read and it said it was an open circuit to speed sensor. Sometimes my speedometer quits working when i am driving down the road which would make sense, but if i tap the dash the speedometer starts working again whichs makes me think its in the guage cluster and not the sensor. So if that is the problem would that make the code go off? Also does anyone know if a 92-94 cluster will work in my truck. If I do have to replace the cluster I like the 92-94 cluster better with the needle guages instead of mine. Looking at them they look the same in the truck but will it plug in and everythig work. Please help. THANKS
Exact same problem with my 89. Pulled the vss connector and it was full of trans fluid. Leaking past the seal I suspect. Replaced. Erased codes and all was well for about 20 miles. Then speedo stopped working again and flashing brake light (code 9) came back on. Tapped speedo and it came back on as usual. Guess the next step will be to pull the cluster and see if I can find a short or loose connection. I had figured the cluster was the best bet but since the vss was leaking anyway and it was only $25 no big deal to replace.
Jim
I wish this forum was around when I had my '89. It did EXACTLY the same thing with the 9 flashes. Everything worked perfectly though. ABS (rear only) worked great, stopped great, etc. I got so frustrated that eventually I just stuck a piece of black electrical tape over the flashing light and called it good.
Did the cluster fix your truck?
If that question was for me: I haven't checked it out yet. I would think that since a tap gets the speedo working again something is loose or shorting. I'm sure the trick will be in locating it. But I'll give it a shot.
Do you guys know if a 92-94 cluster will work in my truck? That is an upgrade i would like to make if i change clusters. I think the only year without a tach is 94 though. They look the same but I was wondering if it woud plug in and work or not?
  • 3 weeks later...
Just an update. Pulled the speedo cluster, cleaned the contacts and reinstalled. No fix. Now battery cluster doesn't work :D . Couldn't figure out how to pull whole instrument cluster out and was afraid to pull on it too hard. So couldn't check to see if there was a crack or anything on it.
I noticed the speedo is driven by some sort of motor or magnetic winding. Still thinking problem is in that particular cluster since a tap on the front gets it working again. I'll continue to troubleshoot it but I need to get it through inspection soon. So far I've found that if I make sure the speedo is always working (tapping on it) I don't get any codes.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
