Borla Or Gmpp Performance Exhaust?
Hi all I'm new to the forums. I was wondering if anyone could recommend which exhaust I should go with. Also I think I read somewhere that Borla makes the GMPP exhausts, if they do then is there any difference besides the tips?
The GMPP exhaust systems are made by Borla,or I should say.."were" made by Borla,I just found out a couple days ago that GM is no longer marketing or selling performance exhaust systems (IE-No one is licensed to produce them under the "GM" name)
Custom exhaust systems are the way to go! Find the guy in your area that does all of the Custom Hot Rods... not some lame muffler franchise. You'll get something designed for YOUR truck that way and get to pick every option.
I love mine.
Straight Pipes :D hahaha, I got a flowmaster 40 series muffler and bought my own pipes and its 45 degree out the sides, I like it, but I have since found out that I can get it inspected as long as there is a muffler there granted there dont have to be anything in it, but it has to "appear" to have a muffler on it :cool:
i have a single 40 series in the same location as the stock muffler. 3 inch in dual 2.5 inch out. and it turns down before the rear end. sounds amzing and looks clean
Thanks for the input guys. Only problem i have with corsa is that from the sound clips I've heard it doesn't have a deep tone, the borla and gmpp exhausts have.
It's deep enough
+1 :D
+2 !!
Corsa Sport all the way!
Do you see a pattern developing here :thumbs:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
