Spongy Brake Pedal
I have a 1996 K3500 dually with drum rears. I also have a ridiculously spongy pedal and no matter what I do, they still suck. The pedal hits near the top but as you apply pressure, it's like it reaches a point where it has no more power. Keep pushing and the pedal will hit the floor. Pumping up doesn't help. I bench bled the master cyl as required, I completely rebuilt the drum brakes on the rear with all new components, including springs, completely flushed all the old brake fluid out of entire system as well as installing new pads on freshly turned rotors on the fronts.
My question would be are there other components that can cause these issues? Can the ABS system have air in it? Is there a Rabs valve to deal with? Is pressure bleeding required or can you use the old stomp on the pedal till you have pressure system to bleed the brakes successfully?
I am using my 1996 K3500 as a wrecker. Typically, the ass is loaded heavy and the front axle gets light. this thing wouldn't stop properly even loaded with a p***ants motorcycle. The fronts will do all the work and the rears just lay there like a girl that's so good looking she doesn't think she needs to participate.
How are your brake lines? Could possibly be swelling up slightly reducing the pressure to the brakes. I've read that SS brake lines help with the spongy feel and that's my next mod this spring.
I agree. My pedal felt spongy in the '04 Yukon when I changed the pads and rotors. I then swapped out to Russell Stainless steel brake hoses and the difference was like night and day. Much firmer pedal and better stopping distances. If your lines are ten years old I would highly recommend changing them. Even if the hoses look good from the outside, they can still be bad.
Hmm, all good on my truck. Recently replaced.
I think I may have come across what my issue is. My K3500 uses the JB8 (build code) Hydro Boost brake system. Lately I have noticed that my power steering fails when the engine RPM's get down to an idle and since the power steering and the brakes run off the same pump, I might be looking at a failing pump assy. The truck can't lock the wheels up and getting into a scenario where I need to stop quickly is dicey at best.
The truck has very high miles (256k plus) and the steering box is also a little loose. I am going to replace the steering box and the pump assy because of the high miles and I think doing this just might solve my problem. On a hydro boost brake system, it is possible to push the pedal to the floor and this is normal. The lack of pressure being delivered would cause the braking power to be weak and would make one think the system is spongy even though it's really not.
I'll report on what happens after the repairs are complete.
Same story on my 1990 Chevy K1500. After I replaced the master cylinder, never was able to get a full brake pedal back. Paid to have them power bleed, no difference. Good luck!
  • 3 years later...
Well It happened again. Spongy pedal after pad change. The whole system is running clear fluid after I bled it. No air was in system. I bought AutoZone's duralast cmax ceramic pads and I have the spongy pedal. Was fine before. I'm getting tired of this. I have a feeling that the cmax pads are junk. There is 2 inches of pad contact compared to the ceramic pad from advance auto pads with 3-4 inches of contact.
It sounds like you are on the right track. Try a different brand of brake pads and if that doesn't fix it, I would re-place the brake hoses and calipers up front also. With the age of your truck, replacing all of it isn't a bad idea anyways.
Well if you haven't done the hoses, I would change them out while you change the pads. Bleed the system of air when you are done and you should be all set. If that doesn't fix the problem, you might have a more involved problem.
  • 3 weeks later...
I changed the brake pads and I have my stopping power back. Now I know to never go to autozone for the ceramic pads again.
Before I went to EBC pads and rotors I used the Wagner thermo quiet pads from advance auto. Great stopping power and quiet. Glad to hear you got it fixed though!!!
Glad it is fixed! Thank you for the follow up. To me, Autozone is like the wal-mart of the auto parts stores. Sure they have tons of stores all over the place and their hours are great but 95% of the parts are re-branded junk! Not to mention the packed stores, long lines, screaming kids all over the place and an underhanded staff that usually knows nothing about cars or barely speaks english. I only go to Autozone when I have absolutely no other choice.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
