Vin Number Question
I have a 1967 GMC custom 1/2 ton and have not been able to find the Vin number on the vehicle, where is it hidden. The vin number on the registration doesn't match any I have found looking on the internet for that year truck. The # is CE1590DZC1291A can anyone decode it. Thanks Fred
Was able to decode the vin at http://quickvin.com/ They decode before 1981. Thanks Fred
I ran a few vin's to test that link and it came back with wrong data on some models like the Chevelle/Malibu. Trust but verify.
Look at the driver's door frame just below the latch.There should be a rivited tag there with the Vin on it ... don't think there should be a letter at the end..
