Rc Level Block Uninstall And 2.5" ?
My lease is up and i need to turn in my 07 1500 that has the 2" rc level block on it. My question is how hard is it to take the block out? Can you pretty much just "smack it out" without having to go through all the steps of the install.
I'm buying a 09 ext 4x4 silverado and picking it up on saturday.
My other question is I'm thinking about reusing the block or going with a 2.5" level block I was looking at the top gun customz 2.5" but I'm not sure about that one becouse it's welded block and not a cast. Any thoights would be great.
Yes, you should be able to knock it right out and mail it to me. Then you can get your new one for the new truck. You don't want to stick old parts on a new truck do you. :fume:
I'll give you my address once you get the old dirty kit removed.
I'm actually going in to the goodyear dealer right after I pick up the truck. He's going to give me credit for the LS2's that are on it and I'm going to try the new duratracs that they have out. I didn't really need the 20's that are on the truck but it is what it is. I'm going to go with the 285/60/20's. The guy says they will fit withouit a level but I'm going to install one anyways. The tire measures 33.5" tall so I'm a little skeptical but we will see. The guys giving me a hell of a deal on the LS2's so it was hard to turn down.
I just put the 2.5 top gun customz kit on and it is pretty solid. I took the truck out camping a few days after install and the roads were severely messed up and checked everything afterward and it all looked great still. I was a little worried about how cheap it looked at first but when you get it you will see that it is pretty heavy duty.
Jon did you get a full 2.5" out of the spacer? I'm curios becouse when I took out my "2 inch" RC spacer from my old truck, I measured the truck before and after and I only really got about 1 5/8". The new tires I got look great but they rub just a little on the driver side on a plastic fastener that sticks out, even after a little encouragement from a hammer. Could you measure your fender for me and what tire are you running?
  • 3 months later...
Are you still running the 285/60/20 Duratracs? Are they rubbing with or without the 2" leveling spacers installed? I have been thinking about those tires myself. I have an 08 silverao 1500 crew cab with a 2" leveling kit. The truck sits pretty much dead level front and rear judging by the space from top of tire to the fender edge. I really like those 20" Duratracs but I don't want them to rub.
They might even rub with a leveling kit.... I'd go for a smaller tire.
I have wrangler LT285/70R17's and they rub slightly in the bumps when your turning. Im thinking about putting in a 2" level but i wanna know what kinda job its going to be before i order it.
  • 1 month later...
Sorry about the late post mr1500, things have been a little crazy lately. I am still running the 285/60/20 duratarcs. I put on the RC front leveler blocks from my old truck and tried to run the new tires but they were rubbing at full lock on the front plastic wheel well and also on the backside up against the metal. So I just HAD TO put on the zone 1.5" body lift. The tires still rubbed but just on the front wheel well which I still need to trim, not really a big deal, I would def recommend the body lift from zone. The lift was fairly easy to install and the truck sits alot like the 2500hd that I had sat. I've got about 8,000 miles on the tires now and their wearing well. They seamed a little loose at times when it rains and may not be the best for mileage but their not exactly a highway tire. The tires don't seem to pick up rocks like my bfg a/t did. I haven't had a chance to get them real dirty and try them out but I'm looking for a good hole or two track.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
