Weld Dune 6
Weld Dune 6. 18x10's with 35x12.50r18 Mickey Thompson Baja ATZ's. They are pretty much brand new. Ive had them for less than 6 months. Bought new for 3500. Asking 1700 obo. 707 849 3001
Damn dude! they are all rashed up!
Where did you get that pic? Thats the pic of my 20x12's right when I bought them. Ive spent hours upon hours bringing those back to life. The dunes that are I have for sale dont have a scratch on them. I bought them brand new about 6-8 months ago. You must be a member on gmfs?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
