Stabiltrak Issue
I put a RC 7.5 in. lift on my 08 Sierra an love it. I am still having stab. trak issues. It doesn't work anymore. I called the dealer and they said I would lose it since I changed the height of the truck. I am really not sure though since they don't deal with lifted trucks. Any ideas???
Mine still works fine and I have not heard of anyone else having issues either.
Who cares? Stabilitrak is horrible!!!!!!!!!
But in some conditions...it may also save your life or at the very least, help you avoid a very bad accident.
I noticed that mine went off after my 5" lift due to not having the alignment correct. Once I get the alignment right today I will let you know if it still comes on.
Just got the alignment today and no problems to report. Stabilitrack has nothing to do with the lift I conclude... could be alignment issue if not electrical problem for you.
  • 1 month later...
j-man and blackout . . . both you have the 7.5 RC lift on the trucks in your sigs/
i been wondering what it looks like installed
J has Fabtech and I have BDS.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
