1999 Yukon, No Power To Fuel Pump
1999 Yukon, died while going down the road, towed in, replaced fuel pump, still does not
Hum or run when the key is turn on. I also do not have power to any of the 4 pins
in the plug that snaps on the pump. Fuel pump relay clicks when key is turn on. If I pull the
relay, I have power to 1 of the posts. Does the pump relay run thru the oil pressure
switch? Or what else can I check. My brother has a 96 GMC, swapped fuel pump relay
with no change. Any ideas? Thanks
If the fuel pump relay in the engine compartment is clicking when the fuel pump should be coming on, but you have power to only one connection to that relay, and that connection is to the relay "coil", then you do not have power from the fuse block to the relay contacts.
Following is a relay diagram. This is probably not exactly like your relay. But on the left is an electromagnetic coil. When electricity flows through the two wires for the coil, it acts like a magnet and makes the little lever move over. This is the click sound you hear.
When the lever moves, it makes an electrical connection on the right side.
The electricity to power your relay coil would come from one fuse. And the power for the contact/switch (which would go to power the fuel pump) would come from another fuse. So if you do not have power to that contact, then there is a blown fuse or a wiring problem between the fuel pump fuse and that relay contact connection.
I had this problem on another truck and found out after it being dead for a couple weeks that there was a small break in one of the ground wires on top of the fuel tank that was causing the pump to ground out and when i mean small break i mean like the size of a pencil lead. " found that after putting 2 different pumps in when the original was fine "
Good Luck
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
