Guess.
Man you hardly ever show up any more.
Well this board went down hill for a while. (not due to mods or staff)
But I plan on being around more. I have some plans in store for my truck.
Guess.
BOOMER!!!!
  • 6 months later...
  • 3 months later...
We’ve never used hard money lenders but might consider it if we are not able to raise private lending. Secured by real estate (note and mortgage) for short term 90-180 days or longer term.
We would probably choose Krueger over red dirt due to the time limitations and high points. 5 points is NUTS! but it sure beats not having any money.
Guess.
Guess.
WUT?
  • 1 month later...
Guest NobleHdwe
I'm a new guy here from Noble.
from tulsa, but live in kiefer now.
BOOMER SOONER!!!!!!!
Ardmore.. this is where I live.. not where I'm from... :confused:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
