Anyone Own Both An Older Yukon/burb & A Silv/sierra?
Does anyone own BOTH a Yukon/Tahoe/Suburban and a Silverado/Sierra? I need them to both be of the older body style (e.g. 2000-2006). If so, please let me know b/c I have a question that requires looking at both of them for a difference with the fender.
Yeah - I've got a 2005 Tahoe and a 2001 Yukon XL. I hope this isn't gonna be a a trick question, as I haven't been studying much................. :thumbs:
I am trying to determine if there is a difference between the rear wheel wells/quarter panels. I am considering buying fender flares from a 2000 Silverado to fit a 2002 Yukon XL. I am unable to see the difference; however, the manufactuer has told me that the front flares are identical, but there appears to be a differnce in the rear but he is unable to see what that difference is.
What I am hoping for is someone to look at both of their vehicles (front and rear fenders) and see if they can tell a difference between the two models.
I've got an 02 Silverado w/ the factory flares....my parents owned a 2001 Tahoe (4 dr). The rear flares on the Tahoe were a two piece design if I'm not mistaken.
Oh yeah, good point John. My uncle has a 03 or 04 tahoe with fender flares and because the rear door is cut to follow the wheel well, the flares he has are a two piece setup.
found a pic:
Cduke since you have an XL, the flares off a silverado "should" work I would think unless the shape of the panel is different :thumbs:
Thanks for the help. I, too, think that they should fit. I am not sure why they have a different part number since both have what appears to be the same cutout over the wheel. I can certainly see why the Tahoe/Yukon (non-XL) would be different, but cannot see see what the difference is between the Yukon XL and the Siverado's.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
