Rear Diff Oil Change
Hey guys...ive got a 1997 Chevy Z71 and i want to change the gear oil. But i dont know where to fill it to. Do i fill it until it starts coming out of the fill hole? Or does it have to be .5-1.5 inches BELOW the fill hole? Thanks for reading and your input...
ok. so i stupidly took the cover off and drained all the fluid before i took out the fill plug. Now i cant get the fill plug out to fill it back up.
AAHHH, the things we learn through life.... Clean up around that fill plug with a wire brush and some brake cleaner, then spray on a little Blaster to soak into the threads.
--Mike
Always will to the upper range of the spec, i.e. 0.5 inches from the bottom of the fill plug threads.
On every other vehicle I ever owned (and I owned quite a few) you always fill through the fill plug opening until oil starts running out. Why does GM have to be so special?
    overspeed
    overspeed
  • Who's Online   5 Members, 0 Anonymous, 1,142 Guests (See full list)
