Nj Trucks Come On In!
Hey guys. My name's Chris. First post here (but i've been ghosting the boards since even before I got the truck). I've had my 99 GMC 1500 for about a month now. This is my first truck after an 86 GN, 99 GT and 00 Cobra. Got tired of the little cars and decided to get a truck. Since I've had the truck I put on a 3" RC lift and 20" XD 797 Spy's with 33x12.5x20 Nitto Mud Grapplers ( with trimming of the front bumper haha). So I thought it was BA for about 1 day before I needed another 3" and want to do a body lift. I did the suspension lift in my buddy's driveway, but not confident enough to lift the body off my truck just yet, and I don't think I have the necessary tools to do so. I'm either looking for some reputable truck shops in NJ, or some good people in NJ that just love working on trucks and would wanna help me out for a few hundred bucks and a case of beer lol. I live in Sayreville, NJ (central ((exit 120) Please let me know if you know of any shops or dealers that will instal aftermarket parts, or if anyone wants to do a BL one weekend? I'll post pics of my truck in the fullsize section soon! Thanks, Chris
Hey Chris, welcome to the site! (dont know how i didnt see this thread earlier :) )
Body lifts aren't overly "difficult" to do... more time consuming than anything. I assume your truck has the electronic transfer case right? (no floor shifter?)
....however, with a baby on the way, i could use a few extra bucks...
and where are those pics??
Oh I hear that man!!!
OK 4WD is a pretty popular place it seems...I pass it from time to time...
ok4wd
I've heard a lot of bad stories from ok4wd....
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
