Good Riddance Tundra!
WhiteRabbit
Greetings from Sunny Florida!
I am very happy to claim that I am the proud owner of a new 2009 Chevy Silverado LT Ext Cab. I am so thrilled with it and just love everything about this truck. Especially how comfortable and smooth it is to drive. The Tundra, OMG what a POS! People carry on about the great Toyota Quality but I didn't see it being immune to typical quality issues and let me tell you that thing had a BOUNCY gut jiggling RIDE. Toyota and their open C-Frame under the Box!. Ugh!.
I can't wait to get started on my new Silverado. I want to go with some bigger Wheels/Tires, Tint the windows, do something with those black door handles that stick out like a sore thumb. Either go with painted door handles or chrome covers, Running boards The WORKS!.
This thing is loaded too with everything from Remote Start, to bluetooth, Power seats, Power folding Mirrors, everything but Leather and Nav. Which is okay with me!.
Thrilled to be here guys!
Welcome to the site. Glad to see your enjoying your new truck. When you start getting new stuff on show some pics. :)
Here's an update. A few mods..
Painted door handles and Mirror caps, Nerfbars, Tinted windows..
Still need either bigger meats on those dinky wheels or bigger wheels altogether. I would kill for a set of Z71 20's.
Welcome to the communit!
Good to see that you are modding nice and quickly. By the way, what % tint did you decide to go with?
I wanted to match the factory privacy glass and was told by the tint shop to go 15% on the sides so thats what I did. It's a wee bit darker than 20% which was what I was going to do but its nowhere dark as limo!.
and thank you all for the compliments and Welcomes!
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
