I just spent a good amount of time reading these posts and wish I did so prior to purchasing my 2015i Suburban LTZ. I have noticed the wind noise which at first caused me to think either the driver side or rear passenger window was opened. I do not feel the pressure or notice the buffeting but will check again to see if I am experiencing that issue. The wind noise is a constant "wooshing" wind sound that occurs at most speeds. I also have a dash rattle that occurs on the driver side just over the console when I drive over bumps. If I drive and hold down the joint between the console and dash the noise is reduced.
I'm not looking forward to family road trips in this vehicle or the process for having GM make this right. I have an appointment with the dealer this week. Should be interesting.
CI Houn - there are 4 issues that dominate this thread, Shaking/Vibration/Buffeting/Pressure.
Shaking and vibration, no one has resolved the issue, a few have gotten rid of their vehicle, more than a few just deal with it for various reasons until or if they can get out of the deal.
Buffeting and pressure, 2 instances of claiming to have figured it out. (1) a dealer changed out the rear end. (2) another fella used cotton balls around his microphone. Few have gotten rid of their vehicle, more than a few just deal with it for various reasons until or if they can get out of the deal.
Cotton balls? Is it a cabin pressure problem or a sound electrical issue
One fella used cotton balls around his noise cancellation mics and he says they eliminated the buffeting and pressure. Nothing written on this thread pertains to an electrical issue. Story too long to talk about the cotton balls. Type cotton balls into the search window (this topic) to get the background.
I believe each scenario is different depending on the sensitivity of the person experiencing the buffeting. I have come to believe all the vehicles have the issue to some degree. For the record, mine is a SLT, standard length, and I do NOT have the ANC mics. Due to this fact, I believe the mics enhance the issue, which I believe to be a mechanical one. This would make sense if the cotton balls used in those vehicles with mics muffled or canceled the 'enhanced' sound to the degree it could not be heard by that particular individual, or perhaps it did not work on another particular individual because of their sensitivity to the buffeting is greater.
The sweet spot for the buffeting in my vehicle is 43 MPH, however, my wife can barely hear the buffeting, where I can hear it loud and clear and feel the pressure. I have been working with my dealer who has been very helpful. The service manager rode with me and we did several test to rule out if the issue was a V4 -vs- V8 mode issue and found out it does not matter what mode the vehicle is in, the buffeting is present.
We now have a GMC engineer involved, and he also believes it could be a rear end issue as mentioned by another poster. The next step is to measure the backlash on every tooth in the rear end to determine if the rear end is indeed the culprit. Hopefully I can have this done next week.
As for 'just dealing with the issue', we are doing just that. It is not that big a deal to me and as I do not drive this vehicle as my primary vehicle and as stated before, my wife can barely hear the buffeting, so no issue with her. My dealer has been very helpful and determined to figure this out.
I understand each situation is different and I'll report back the findings.
Edited by cleanfreak
Are these problems only on the long ones or on the shorties too?
As per my above post, mine is a standard length Yukon or "shortie" with the issue.
i had the same issues, now repaired; the entire rear end/axle assemble and drive shaft were replaced via GM engineering personal.
I have owned 3 2015 Yukon Denalis. One an early production model and two 'interim' models. None had this issue. I have not found a vehicle known to have the problem I could test and measure. That is not to say the problem does not exist ... it most certainly must; however, I suspect it is in part the vehicle's engineering and in part individual sensitivity to the intensity and frequency(ies) involved.
Was it an xl version?
So this solved the problem.
I know on my 02 denali with 200k plus miles on it developed a rear end issue that would vibrate the vehicle at 55 mph and would go away below or above that. It was a rumbling that would caused that similar effect. Actually might have been the drive shaft
Ok. Going to rent a Tahoe lt tomorrow
Thank you for your reply. You have a PM.
Hope that's it. Cause I want my denali
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
