***Buffeting Update***
The ring and pinion backlash has been measured and was found to be out of required specifications. The ring and pinion was replaced along with the driveshaft. I went yesterday to drive the vehicle, but it was very hard to make a determination if this indeed solved the issue, as it was raining heavily at the time making it difficult to hear, but I believe I still heard the ‘buffeting’ sound.
I also contacted SPDYPRNT’s Service Manager to see if he could help. I have to say, he has gone above and beyond, even though he is over 1000 miles away and not physically dealing with my vehicle. He stated they did the same as my service above, but the ‘buffeting’ sound was not resolved until they replaced the side bearing races in the differential as well. These side bearings had an “hourglass” shape due to backlash being out of required specifications. He also was nice enough to send me the complete parts list and the technician notes on the repair.
I have forwarded this information to my Service Manager in hopes he will do the same. I am out of town today, returning tomorrow, and I hope they have time to make this last repair to the side bearing races before I arrive to test drive again.
I will update accordingly. Until then, here is the complete parts list and service order the other Service Manager was kind enough to send to me:
Parts:
QTY 2, 12471686 - SEAL, R/AXL SHF
QTY 2, 12479031 – BEARING, RR WHL
QTY 1, 14038010 – SHIM KIT, DIFF DRV P/GR BRG
QTY 2, 15286384 – RING
QTY 2, 22786619 – BEARING ASM – DIFF
QTY 2, 22835276 – SHIM KIT – DIFF BRG
QTY 1, 22934114 – SPACER, DIFF DRV P/GR BRG
QTY 1, 23114036 – GEAR KIT – DIFF RING & PINION
QTY 1, 23126912 – DIFFERENTIAL ASM/LSLIP
QTY 1, 23168731 – SPACER – DIFF DRV P/GR BRG
QTY 1, 23199120 – HOUSING ASM – R/AXL
QTY 1, 26063647 – CONNECTOR, R/AXL VENT HOSE
QTY 1, 12471607 – MAGNET, R/AXL HSG CHIP COLLECTOR
QTY 1, 22943108 – BEARING
QTY 1, 22943111 – SEAL
QTY 1, 22943106 – BEARING ASM – DIFF DRV P/GR INR
QTY 1, 114454 – AXLE ASSEMBLY
TECH COMMENTS:
Road test numerous times to pinpoint concern. Road test similar vehicle and verified concern is not present. Found concern to be most prevalent on decel at 43 MPH. Install Picoscope and record measurements. When “droaning vibration” occurs, prop shaft 1st order rises to 450nG. Remove rear prop shaft and drive vehicle again. Sensation is still present, but not as severe. Therefore did not swap prop shaft from known good vehicle. Call TAC- case XX-XXXXXXXXXX. Advised (due to Picosope readings) to measure backlash on each tooth of the rear ring gear. Found backlash to be between .011 and .001. Remove differential assembly (it was very difficult to pry from axle housing) and found side bearing races to have an “hourglass” wear pattern. Per TAC, NEC to replace axle housing, ring and pinion, and differential (may be causing ring gear run out concern). Attempted to obtain an assembly, but it is not available. Send out axle for setup due to pinion depth gauge not available in a timely manner. Reassemble rest of axle (axle bearings, ABS reluctors, seals, backing plates, axle shaft, cover). Install axle and road test. (total of 34 miles including diag road test). Sensation is gone.
Great update! Sounds like they are getting somewhere...slowly but surely. Hopefully you get a resolution. Please keep us updated. I am interested to know if the folks in Arlington about to build the 2016s in a few weeks know about this...or care?
Those of us following this thread from the beginning used to see GM reps chime in from time to time. They have gone completely quiet...Unlike the buffeting in some the 2015s.
Jasondenali, similar to your experience I am on my second 2015 Denali xl. I bought the first one March 2 2015 with a build date of 2-13-15 and got into the one I have now on June 3rd,with a build date mid March. The first one was fine until about 300 miles then the earaches, headaches and just feeling lousy everytime I drove it started. I had to wear ear plugs all the time in it. Went thru the whole service thing, pit5318,ring and pinion, to them changing the entire rear from rotor to rotor and nothing fixed it. After two months in service they took it back. The GM rep and my dealer were great and made the whole process of swapping the vehicles easy without any cost to me at all. Getting in touch with the GM Executive Office and starting a case also helped and then it went to the repurchase dept .I only have about 600 miles on the new one and so far no problems(fingers crossed). I wish anyone going thru this good luck.
Were the able to tell you what, if anything, is different about your most recent one?
You make me feel better that I am not the only one to give GM a second chance after such an awful first experience. I hope this one works great for you. I noticed the pressure and headaches around 250 miles with my second one...hope you are on the road to happiness with this one and it stays perfect. Please keep us posted.
There may not be anything structurally different, trucks like mine don't have any of these issues. To find anything different would force GM to admit they didn't conduct or report appropriate quality control of something wrong in the beginning.
Very good line Jason
It's commendable that independent dealers are doing what they can to mitigate the buffeting problem, but I can't see how replacing a non-defective part with the same part is going to solve the buffeting, just doesn't make sense to me? The tech did mention a couple of things, the "hourglass" wear pattern and the backlash, but didn't say if that was abnormal or not. Addressing these things with the same part will result with the another hourglass wear pattern and the same backlash?
[/The only thing they did was tell me your out of this one and pick out another one on the lot. The difference between the two is color,steel gray and chrome wheels. I wanted to wait for a 2016 but this was the only way they would do the swap. The dealer even gave me a letter saying if the new one has the same problems they will do it again. quote]
Jason Denali, thanks. I really like the vehicle and the way GM and my dealer handled the whole process. They also gave me a letter stating they will replace this new vehicle with another if I have the same issues. I know this doesn't define what the problems with these trucks are but I hope they find out soon.
Dealer sent me an email about a vehicle I inquired about. Seems like a lot of these might be on the used car lots now
Hello ,
Thank you for considering Sutliff Buick GMC Cadillac for your automotive needs. We know there are many dealers out there to choose from and appreciate being on your list. We are here to provide you with the information you need to make a decision that is right for you.
My name is Janelle Orris, I am an Internet Sales Assistant for the Sutliff Auto Group. I will be happy to assist you with your next vehicle purchase.
We recently received your request for information on a 2015 GMC Yukon. As of now, the vehicle you inquired about is still available for sale and ready to drive! I have attached the only picture I have at this time. This vehicle does not have a sunroof.
So you are aware, the prior owner said there was a vibration in the back end of this vehicle so GM had us rebuild the back and replace all the tires. The customer was still unhappy and GM gave them a trade assistance which got them into another Yukon Denali. You will need to sign a disclosure notice if you should buy this vehicle. Currently my Sales Manager is driving it and does not notice any vibration.
2015 GMC Yukon 4WD 4dr Denali
Yukon
Internet Price:
$59,994
Type: Used
VIN: 1GKS2CKJ4FR200995
Stock: 41706A
Style: 4WD Sport Utility Vehicles
Engine: 8 Cylinder Engine
Transmission: MYC ELECTRONIC 6-SPEED AUTOMAT
1 Click for Images Click for Details
Please let us know when you would be able to come in and take a closer look and/or test drive the Yukon. Our showroom hours are Monday through Friday 9:00 am to 8:00 PM and Saturday 9:00 AM to 5:00 PM.
We look forward to hearing from you.
Sincerely,
Janelle Orris
169 W. Aaron Drive, State College, PA 16803
Best # 1.877.895.7565
Next Best # 814.867.4444
www.sutliffbuick.com
This email was sent to: [email protected].
From: Sutliff Buick GMC Cadillac 169 West Aaron Drive State College, PA 16803
Update Preferences - to update your communication preferences.
Unsubscribe - to stop all future email communications [REF_V820559-497212_NO].
Edited by Cl Houn
One thing to buy this truck and it develop issues, doesn't make sense to buy a truck with known issues, especially being a member on this thread. Wouldn't have a leg to stand on if you wanted to take it in for vibration? This is red flag 101
Send this message to Janelle and see what she says. Something tells me she will say the dealership don't know anything about these trucks having a vibration problem, this is an isolated case.
Edited by The Zip
I wouldn't buy this after seeing this, but the disclosure seems like it's as is with the problem so no return. I appreciate them making the customer aware of this problem, most dealers problably won't say anything.
Another used car lot down the block from me jus got a Denali xl and I asked him about it and he says yes it has it too. Right away. Maybe the word is jus about officially out..would think the next step would be a resolution
But most of the used ones seem like they might be buy backs
***UPDATE***
I picked up my vehicle yesterday evening after having all of the work in my previous post completed. I am happy to report the buffeting is gone.
The reason for the issue seems to be pin pointed down to an incorrect backlash setting in the rear end. Some are set correctly and those with the issue are not. It seems there are 2 types of rear ends that were installed on these vehicles depending on availability at the time of the build.
The dealer opened mine up and found the issue. This incorrect setting caused abnormal wear on the ring and pinion as well as the side bearing races. These bearings did have a hourglass wear pattern due to the incorrect setting. They replaced the ring and pinion and making sure the backlash was set per the required specifications and also replaced the side bearing races.
I will report back if the buffeting returns, but for now, it is fixed.
Edited by cleanfreak
***UPDATE***
That's more of a positive answer "replacing the ring and pinion due to an abnormal setting on the backlash". This is the first time on this thread that something was replaced due to finding a problem. Put the vehicle through the test by going over bumps and at different speeds from 25 to 70. A lot of folks will be awaiting you next report. In the meantime, can you post a picture from your work invoice that pertains to the ring and pinion work?
Edited by The Zip
***UPDATE***
OK, now we are on to something! Thanks for the update, Cleanfreak! Like Zip said, this is the first time something was actually replaced and it fixed the problem. Let's hope it is indeed a permanent fix. Please, please, keep us posted with your results. You can help so many people with this issue by keeping us posted. No pressure, man. :)
I am most interested if the issue is gone at 42-43 mph. That is the speed most can pinpoint the problem without hesitation. Those were the speeds which both of my repurchased Denalis had the problem. If you decelerate at that speed range and the issue is gone, I think you will have solved the curse of the headaches, ear pressure, and buffeting. Please let me/us know your results at those speeds. Thanks again for being a team player!
That is good news, but the proof will be after several hundred miles of wear to make sure the problem does not recur.
I agree that this looks very promising. Even the folks on the pick-up thread are finally getting some reports of their vibration issue being solved with new rear ends. Not all, mind you. But of course, if the same defective parts or settings are used, then of course it won't solve the problem. My guess is that GM knows exactly what the issue with the pinion and ring gear are, but getting enough sets to replace all the problem pick-ups and SUVs, while tooling up to build the 2016's, is proving more than their crappy supply chain can deliver. So, they throw some parts from the "suspect" bin at the customer hoping it will either satisfy them or buy GM some time.
I do recall a report about 6 months ago on another website altogether that said they replaced the entire rear end assembly, housing and all, and the buffeting went away.
I also shared some of my research several month ago where I found several papers and a GM TSB that dealt with vehicle cabin boom as a result of pinion gear-mesh issues. So, this would be not big magical revelation if it truly is the root cause. The frustrating thing is that the gear tooth backlash was the very first thing my dealer checked. So, either they didn't check it correctly, or the specs they worked to are not correct. I suspect the latter.
Looking forward to my next conversation with the service department. Keep the reports coming in!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
