Sunroof Rattle
Any of you guys with GMT-900 Ext Cabs have a slightly annoying rattle in your factory sunroof and haven't been able to trace it? I have a rattle that seems to come from the Sunroof Area in the Headliner.... and I haven't been able to trace it thus far...the only thing that will make it kinda quit would be pushing up on the glass every now and then, but I can't figure out if the glass is loose how you would tighten it. I really am dreading a warranty repair for the fear they are going to have to drop the headliner, etc...I used to work at a dealer and know how the trucks come apart myself, so I don't have a problem fixing it myself, I was just looking to see if anyone had any suggestions I might check before I go tearing into it.
Hmm...Mines quiet Travis :rollin:
yeah my 07 was too!! damn, shouldn't have traded :cheers: ...I can't figure out what it is...the only other possible thing is I am thinking some loose wiring up in the headliner??
The retractable sunroof shade on my 07 rattles every now and then. I just push it back further and it seems to stop for a week or so.
mine did this too.. iand for me it was actually the seals. get a good weather stipping lube and apply all over the seals on the sun roof.
another member suggested this stuff http://autogeek.net/1z-einszett-rubber-care-stick.html Einszett Rubber Care Stick “Gummi Pflege"
it worked great for me.
it will button up the rattle almost instantly. i also find that the retractable mesh sun visor will rattle very slightly too. if neither of those fix it, take off the interior headliner lamp (right behind the sunroof) and look for the loose wire. if its not one of those things..well S.O.L! ;)
p.s. while you are lubign up those weather seals on sunroof, might as well attack the rest of them on the truck before they start acting up!
I have the same issue. If it is fully pushed back, it rattles. If I move it to 1/4 closed, it stops?
Its the wind deflector.. rattling inside while closed.
Thats what I thought too, but it seems to be near the back of the Sunroof more than anything....if thats what it is though, I wonder what the best way to fix it would be?? Also I have a little different sunroof deflector than you do...I think your crew has the Plastic Piece deflector where mine has a mesh screen that pops up being an extended cab....
Thanks for the Suggestion....Looks like that product is on Backorder right now, however I'll keep a watch for it! I wonder if this will help the creaking door seals also?
it will def help with creaking door seals. its a great product. u can google it. other places sell it too..def worth the money.
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
