Noisy A/c Compressor
zedbear
Just wondering what the typical causes of a noisy compressor are. It's making a "rrrrrrrrrrr" noise when accelerating. Increases in intensity with RPM. It is most noticable when the heat load is high, like on a muggy day. Don't really hear it at all when it's below 75 and dry out. A/C blows ICE cold otherwise. Thanks.
probably a bead bearing on the pulley, or maybe a bad belt. Mine chirps like belt squeal and is super annoying but apparently not enough for me to to get around to changing the belt :thumbs:
Bad belt, no. Bad bearing, I doubt it. I'm pretty sure the sound is coming from the compressor itself. Its making a sound sorta like a souped up engine with timing gears, lol. Kinda hard to describe this.
sound like a metallic swirling sound? because mine sure enjoys making that noise...idk if it increases with rpms, the engine and the radio tend to cover up most noises
Maybe.
Next warm day we get, I'll hook up my gauges and see whats up. Wondering if the shady dealer I bought it from "topped off" the refrigerant before selling it, possibly over-charging it.
Or it may just need a little oil.
My Impala is noisy, it always has been. My Tahoe is very quiet.
Th
  • 1 month later...
Finally hooked the gauges up. Ambient temp around 80 degrees. Low humidity.
Static pressure was 65/65
At idle, max a/c, doors open: 43/225, vent outlet temp 48F.
1500 rpm, max a/c, doors open: 33/200, vent outlet temp 38F............
Everything looks good there.
I had a compressor get noisy on my '94 K1500 when the low pressure cut off switch took a crap on me. I didn't notice it right away because I always had the radio cranked. The comp wasn't cycling, which caused the oil to slug ... and basically smoked the compressor. Got REAL noisy after that.
Mine appears to be cycling normally. Could the system need a little oil? Or maybe it's just worn out?? Its sort of embarrasing to drive, lol.
If it were me, with 38° vent temps I'd leave well enough alone. I wouldn't go adding oil to a system without knowing exactly how much is in there. Too much oil will smoke a compressor almost as fast as not enough oil. The only way to know exactly how much is to recover the charge & measure the oil. If you don't have a machine, you'd have to flush each component & start from scratch - not something I'd be willing to do when it's working perfectly fine.
Can you shed any light on possible causes of this noise? I wish I could record it but I don't think it would get picked up very well. I may just take it in to a shop to have it looked at. My primary concern is whether the noise means compressor failure at some point. Is "black death" a concern with these systems? I'd hate to just leave it and have that happen. Then I have to replace everything lol.
Thanks for the info.
  • 2 months later...
hey guys, just signed on to try to figure out a problem i am having with a 2000 2500 6.0L. the guys original compressor made a lot of noise for a long time until it quit working. he brought it to me and said he wanted it all replaced with new stuff. i took out his orifice tube and saw it was covered in metal shavings, so i put in a new condenser, new dryer, new orifice tube, and reman (4seasons) compressor. i did flush the system with fjc ac flush and compressed air first. then i put in 8 oz of pag150 oil and charged with fresh 134a. the system works great, blows cold, but makes a lot of noise. sounds like the noise that this post is about. not a terrible sound, just loud. i have checked belt, tensioner, mounting bracket, cant find it. today i got another reman compressor from my parts store (and new dryer and o tube to comply with warranty requirements) and installed the new parts. i put 2 oz of oil directly into the compressor and spun it by hand several times before installing it. i vac'ed the system for 30 minutes and charged it again and...............just as loud as the last one!!!!!!!!!! i dont know what to do, i may have to eat the first compressor i got for it and i have waaaay too many hours into a project i didnt make much on in the first place. anyone have an idea?
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
