Any one interested
stlmaj
Was wondering how many members would be interested in a Missouri meet. Not sure how many we have here in MO.
I would be interested. :thumbs: I have always been curious as to how many members are in MO.
Phil
Looks like there is only the 2 of us? Surely there is more interested may be we should consider the surrounding states and get more involved with them. Anyways if anybody else is interested post and we will set something up.
Matt
Cool we are up to 3 now!! gm4X4 glad to see you’re interested! Any one else?? Do you guys have any ideas as to where, when and what you want to do? If nothing else it would be cool just to check out each others trucks and mods... I am open for suggestion.
Thanks,
Matt
It appears that we are all in the STL area. :lol: That makes it a little easier to pick a spot. We'll have to pick a nice day, probably a weekend, and get together. :thumbs: (hint) My schedule is kind of busy right now but I'm sure we can swing something. Sure would like to wash the truck first to get all of the MO road grime off of it. :dupe:
Phil
Hay look thay added location under are avatars. How cool, now if everyone would just set it up??
Not necessary 3 is enough pjb0422 suggested doing something here in STL sounds good to me. We just need to figure out what we want to do. I work nights but only during the week I rarely work weekends and am open for almost anytime. What fits your schedules?
Matt
Weekends would be the best for me, for now anyway :thumbs: Whenl the weather gets nicer, then I may be fishing.
We have St. Charles, Chesterfield, and Eureka. We could meet anywhere in Chesterfield Commons, on Hwy 94, Westport, someplace close to all of us.
Matt, where are you at in St. Charles? I'll probably be a Bass Pro next weekend when they start their Spring Fever Sale. :)
Phil
Phil
I live off 94 and Kisker and I work in Chesterfield. So Chesterfield is fine for me. I spend most of my summer camping, fishing and traveling. :thumbs:
Matt
Im from Kansas City. I just dont post much any more, since I sold my truck. But, there are about 5-6 KC guys on here as well. I can only think of SilveradoMan(Mike) and 96vortec(Jeff) right now. But, there are some others, you just have to find 'em.
Thanks I will check with them to see if they would be interested....
Matt
I`m in! Pretty much any weekend we pick will be ok with me. I`d like to suggest Creve Couer park as a meeting place. The only problem with it is they don`t allow any :thumbs: since it`s a county park but it`s a really nice shady place.
Cool we are up to four--- fmjcafe, pjb0422, gm4x4 and me. I am cool with any where you all want to meet. I think that weekends are a given any one with a suggestion as to what weekend. It would be cool if we could do it some where we could hang out barbecue, drink and of course check out the trucks.
Matt
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
