Traction Control turning Off
I've got a 2001 Silverado 1500 with 2K miles on it. About 6 or 7 times since I've had it I've had the Traction Off Light  come on. Sometimes it stays on until I shut off the truck then it will reset. It only happens when the road is wet.  Anyone else heard of this.  I plan to take it to the dealer but am checking around first to see if this has happened to anyone else.
Thanks
Dan E
Ohio
That does sounds wrong. I would bet there is a loose wire somewhere!
I'm sure your happy you can take it to MR Badpliars! :thumbs:
I haven't taken in to the dealer yet. I was thinking of spraying water under the truck one section at a time until I found the area causing it.  It only happens when it rains so it is moisture related.
\I'll keep you posted.???
