"burping" The Cooling System / Bleeding Air / Weak Heater
I changed the T-stat in my truck about a week ago. I noticed that the heat isn't as hot as my brothers identical truck.
Could it be possible that I didn't "burp" the truck correctly after I filled it back up with coolant? Engine temp is fine.
What is the proper technique for these specific trucks? (4.8, 5.3, 6.0) I can't find an air bleed hole like on my Impala.
Do I just let it run with the coolant resevoir cap off for a while with the heat on full blast?
Did you check in a pot on the stove and check the opening temp? Should be opening at 195F. Also if its a cheap stat its going to be very marginal on where it will open.
Since your truck has a coolant recovery system as part of the entire cooling system there is no burping needed.
Interesting; no i didn't do a stove check. This is an OEM t-stat. The one it replaced was bad --- only opened after i hit it with a blow torch.
I can`t help with the bleeding, but in the future. Drill a 1/32" hole in the body of the new thermostat. This will allow any trapped air to escape on it`s own.
No offense - BUT - I think this is risky advise at best. I would never alter the only item responsible for maintaining the temperature of my engine's coolant.
The system does require burping. Here is a link to the GM recommended procedure. (given to me by another GM-Trucks.com member)
BURPING THE SYSTEM
BURPING THE SYSTEM
No offense taken, however, drilling such a small hole hole in the side of the body of the thermostat has no measurable effect on the performance of the stat. Even in cold weather the stat opens in about 5 minutes of driving and the small amount of coolant that would sneak through before that happens is minute. I learned this trick years ago and have done it many times with no ill effects.
It's quite possible you are right. I can't see what harm such a small hole would do. It would take a lot more hole size than that to pass much coolant. I must admit I've never heard of doing it... but I learned a long time ago that you can never know it all.
Hey thanks guys for the advice. I'm so busy with everything in life that when I made this post a few days ago I didn't realize that it was 5 degrees outside. I guess I shouldn't have whined so much. Hard to complain now though since its 55 degrees and rising at 11PM!
You must be somewhere near Chicago. I looked and looked for an affordable vacuum filler for the home mechanic. I bought mine 8 years ago for $25 and it has been a great investment. At $145 I would still buy this one but you would have to do alot of cooling system service to justify that, maybe someone can come up with a cheaper alternative somewhere and post it. Basically you put the big plug on the filler(radiator neck or filler bottle per application) you run compressed air through the inlet and this creates a vacuum in the entire coolant system leaving no air pockets. Then stick the filler hose in more than enough coolant(my bucket stays at 4 gallons) and when you open the valve the coolant takes the place of the vacuum. This thing has never let me down I have never had an air pocket since I got it and I don't even bother warming a vehicle up after service to make sure there isn't one. If anyone can find one cheap let us know.
Just finished replacing the water pump on my '03 Savana with the 5.3.
Per the service manual (sorta):
Pull of the purge line from the radiator.
That is the smaller hose that comes from the air intake warming flange and enters the radiator just under the overflow tank connection.
Disconnect the upper radiator hose from the radiator.
Pour in 50/50 DEXcrap into that hose until the fluid escapes from the disconnected purge hose.
Reconnect the upper hose.
Reconnect the purge hose.
Add 50/50 DEXcrap to the overflow tank.
Monitor the overflow tank for fluid level during the next few cold/hot/cold cycles.
Per what service manual?
Sorry my bad that is per the 03 manual. There is a manditory tool that is something like the tools I posted that GM made us put in the tool room because this procedure was unreliable.
I hope this helps. This ino was obtained from "ALL DATA ONLINE".
Notice:</B>When adding coolant, use DEX-COOL coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner at 50 000 km (30,000 mi) or 24 months.
  1. Close the radiator drain cock;.
  2. Fill the system through the surge tank opening.
  3. Pre-mix a 50 to 60 percent solution of DEX-COOL and clean. drinkable water.
  4. Slowly add the pre-mixed solution to the surge tank until the level is slightly above the surge tank split line.
  5. Start the engine.
  6. Idle the engine for 1 minute.
  7. Loosely install the surge tank cap. Do not allow the system to build up pressure.
  8. Cycle the engine from idle to 3000 RPM in 30 second intervals until the engine coolant reaches 99°C (210°F) and the thermostat opens.
  9. Shut off the engine.
  10. Refer to step 3 in order to remove the surge tank cap.
  11. Start the engine.
  12. Idle the engine for 1 minute. Fill the surge tank to 1/2 inch above the COLD FULL mark on the surge tank.
  13. Install the radiator surge tank cap.
  14. Cycle the RPM. Idle the engine to 3000 in 30 second intervals until the engine coolant reaches 99°C (210°F).
  15. Shut off the engine.
  16. Top off the coolant, as necessary, to 1/2 inch above FULL COLD mark on the surge tank.
  17. Rinse away any excess coolant from the engine and the compartment.
  18. Inspect the concentration of the coolant.
What ever happened to the 'ol days of ...
Fill radiator
Leave cap off
Start engine
Wait for t'stat to open
Top radiator
Cap radiator
Close the hood
Open a cold beer
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 854 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
