So I Was Bored Today And Went To Gm Headquarters
Hey I am in windsor right now and I wanted to waste some time. So I went to Detroit to the Renaissance center because I interpreted that it had 50,000 sq ft of cars. Well it turns out the whole buiding is 50,000 sq ft and not that many cars :thumbs: . O well here are some pictures of them.
Nice pics. Looks like you had a good time.
Yeah it was fun. I was hoping for a Corvette pace car or ZR1 or Camaro
H3 Alpha?
Yes, I thought the mirror was cool so I took a pic
H3 Alpha?
That's the kind with the pop out rear view camera, huh?
Yeah, I never knew that.. cool
Pretty cool pix. I need to get bored and go out and do something like that. This damn working 12 hrs a day is about to kill me. :idiot:
Gotta come to Indy to see these. About a month before the Indy 500 there are a bunch of them driving around here promoting the race. This years pace car was pretty nice.
So I went to Detroit to the Renaissance center because I interpreted that it had 50,000 sq ft of cars. Well it turns out the whole buiding is 50,000 sq ft and not that many cars :idiot: .
??? The Renaissance Center is over 5 million square feet....
    • I installed the Auto stop eliminator on my 21 Sierra SLT shortly after I got it. They have a detailed video instruction on how, took me about 20-30 minutes to do. I was apprehensive too to start tearing apart a new truck but it was pretty easy install. Like you mentioned get some trim tools. I went to Harbor freight and picked up a set. If you can find some install videos/instructions to give you and idea for a plan of attack you should be fine.
    • If all oil manufacturers had to meet a higher standard for not just the initial filtering of the oil but that they had to improve on their formulation so that the oil cleaned the engine such as the Valvoline R&P or the new Mobil product ( assuming it works similar of course ), and the oil was changed on an interval based on good UOA data, there shouldn't be any gremlins running around like miniture rats on top of your heads to be washed down into the oil pan below 😁
    • Worst factory HD wheels GM makes
    • A while back on another thread there were comments and thoughts on air filters and I know that can tend to be a bit of a hot topic because of outfits that have a vested interest in selling aftermarket air boxes fitted with the gauze type of oiled elements touting the lower air restriction. However and unfortunately I don't know where I have seen the test results in the past about the amount of dirt through a test procedure that these style of filters do pass more dirt through than a properly designed ( not some cheap Chinese knock off ) paper/synesthetic media filter can do. Lake Speed had a conversation on that topic with one of the employees at Donaldson and there seemed to be a consensus of these oiled filters falling short in the absolute percentage of dirt holdback.    Which all ties back into how good the air filter is on the engine at keeping dirt out as that is going to reflect as a contaminant introduced into the oil as well as cylinder wear even if some of that dirt does find its way out of the exhaust rather then the crank case. Put another way that one can throw the kitchen sink at filtering the oil and using a bypass system which I fully expect will do nothing but good for the oils contamination but if the air filter system isn't doing its job then its preventing the engine from reaching the best wear/lasting case scenario instead.    Now perhaps this topic is or isn't for this particular thread but Grumpy Bear or anyone else for that matter, do you have access to some scientific trust worthy testing on engine air filter types to get some proper comparison data to post up.
    • WOW, something we agreed on. I only bought at sticker twice. A 94 impala ss and an Acura intagra type r. Made money on the first. Still have the second.
