Fog Light Switch
nick-o
This a random question, but i cant help but notice that every time i turn on my headlights, i have to push the little gray button to turn on those sweet looking fog lamps. My question is why is it that way, and is there a way to change it so that the lights come on with the headlights, and then i can press the butoon to turn them off?
Any insights would be awesome.
There are lots of How-To's about doing a HI+LOW+FOG mod on here (search is your friend).
EDIT: I just produced the I-D-10-T error on myself
Those are all taking about wiring low and high beams together. Im just takin about lows and fogs. Ill keep serching for the right thread.
Put a diode from post 85 on the low relay to post 85 on the fog lamp relay. Post #5 from the previous link show a picture of the electrical center.
Ive found the diode way, and it looks like it will work, but does that override the button in the cab? If so has anyone heard of a way to just reverse the switch. Meaning the fog lights come on automatically and then you need to push the button if you want them off.
The diode overrides the switch. To set it up like you describe you'll need a 3 way switch; switch up to have the fogs come on with the lows and down to have the lows on and fogs off. That should be easy to do though.
do you think i could reverse wire the existing switch? or maybe get another switch like the one for cargo lamp and swap the fog switch with that? I just want to keep it looking stock.
I think you're going to have a hard time adding another button to keep the stock look. You do have a spot next to the passenger airbag switch, where the quadrasteer button should be, that can be added but it would be an on/off switch. I added something like this for my aux back-up lights, 1st picture in post #11 link
You could do the same thing the switch would stay in the up position and the fogs would come on with the lows, switch it to the down position and the fogs would work independent. It's not as easy as the diode but it can be done. I got all my electrical supplies including the wiring clips for clean connections at the MBEC from mouser electronics.
Alright thanks, ill see what looks the best switch-wise and then try that way. Thanks for the ideas.
You have the stock setup so I don't but for those without the stock setup I went with an after market pilot switch kit with relay. I get the desire effect that you are wanting every time but I'll admit the first time I hooked it up I was baffled, the daylight sensor was throwing me off (it was the middle of the afternoon - it took me 15 minutes to figure it out).
"Fog lights" should be illegal, and their use punishable by death. I'm going to start mounting airplane landing lights to my truck to deal with you people with your HIDs and fog lights. Fog lights are yellow, and for fog. People running those white, yellow, purple, blue "fog lights" should be punished using the aforementioned method.
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
