Way Pissed
Hemi
so i went mudding yesterday and didnt get a chance to wash the truck.  i know that makes it hard to get off, but i just didnt have time (plus it looked cool).  anyway i drove it to school and parked it in the lot, lots of people talked to me about it.  Sometime during the day this girl i know (and dislike very much) decided how cute it would be to write me a note in the mud.  so she writes a note in the mud on the hood complete with big stupid heart and signs her name.  apparently she used a stick or a key or something because she managed to leave scratches everywhere she wrote.  you can still read it after 3 coats of Color Cure Wax!!!  anyway, im getting a quote tommorow on how much its gonna cost to get fixed, and she (or her parents) are gonna pay for it even if i have to take them to court.  Usually i wouldnt be so pissed but i really really didnt like this girl (no one does) to begin with, and i love my truck.  I really dont want her name etched in it forever.  Sorry im rambling, i was just very angry and had to vent.
Ouch...that sux man :D
My neighbors z-28 Camaro got keyed bad last weekend :angry:
Quote from NeXuS1, posted on Nov. 19 2001,10:28
is she hot?
she aint half bad, just annoying and blonde (in a bad way).  knowing her i could probably get her to do anything i said right now seeing as she hurt my truck.  shes always liked me (hence the heart now permanently etched on my hood)
oh man sorry to hear about that
Id be SUPER pissed
my gf has joked like taking her key to the side of my truck.  I know she would never do it but i still stop and give her this look
That sucks. I know how you feel, I have two big key marks on my door. People just don't think...  :angry:
bassdog
Sorry, to hear about you truck. At least she didnt REALLY try and make it a permanit accessory to your truck. The  she might have done more damage then what she already did.
One of the managers at work last night was threating to mess with my truck. So, I told her if she did, she would get a ice cold bucket of water throun on her. She changed her mind, when I reminded her she was wearing a white shirt and it was 30 some degrees outside
Just got to love that.   :angry:   I don't have a problem with scratching my truck up by being off-road, etc.  But when somebody else does stuff to my truck, that kind of pisses me off.
Kid at my school got jumped the other day by kids from another school.  They kicked the #### outa him and kicked off his rear view mirrors, and left some key marks on his 95 mustang.  I don't really like they kid and he prolly deserved an asswhoopin but nobody needs their vehicle F***ed with....its like you already beat him up, why add total insult to injury?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
