Middle Console
I purchased a truck back in feb. The middle console lid was broken off the hinge. I made them fix it before I picked it up. Well there idea of fixing it was to through 2 little brass hinges on it. Although I didnt like the idea after I saw it. It worked and there wasnt much I could do about it. Small price to pay for the deal i got on it. Well one of the hinges snapped the other day and the screws are pulling out of the other one because its only plastic. This must be a common problem. What has anyone else done? Is it possible to get a new lid? I dont have any idea how it mounts on there because i have never seen it factory. whatever was there is gone.
Same problem here man! I called the stearlership and was told the part required to fix the hinge would be $160!!! Heck, I can get a whole new console for that price!!
I have taken apart the console lid and i think that a piano hinge with self taping/expanding screws would do the trick. I have not done this yet but it seems like the easiest and most logical solution besides paying BIG money to fix a bad design!
John
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
