Gm Upfitter Help
According to gmupfitter.com page A-67 my truck should have aux 12 volt power wiring already installed. I cant find the wire ends like it states where they are.I thinkI have found where they come from, the junction box on right end of dash.any help on where they are would be great.
heres what it states
Electrical Connections
Your vehicle is equipped with wiring provisions for a 12-volt power supply (SEO
9L4). Refer to the following information when adding electrical accessories that
will use the 9L4 12-volt power supply feeds connected to your vehicle's electrical
system. After reading the following information, keep it with your owner's manual
for future reference.
Notice: Before modifying or adding any wiring, be sure that it will
work properly with your vehicle's wiring system. Because there
are so many modifications that can be made for many different
bodies and accessories, GM cannot take responsibility for any
changes made. Such changes may not be covered by your GM
Warranty. Have the work done by an experienced electrical
technician. All wiring must be properly protected by fuses, etc.
and must be routed properly so that it will not be cut, pinched or
rubbed by other parts of the vehicle. Do not route wiring in areas
where it will be very hot. Be sure not to overload the vehicle's
wiring, connectors and components. All added wire must be at
least the same size as the wire being attached to for proper fuse
protection.
Installation Instructions —
12 Volt Accessory Power Supply
1. Disconnect the battery negative (-) cable at the battery. The
negative (-) battery cable must be disconnected before the
positive wiring lead is connected to the power accessory.
2. Locate the power supply harness under the instrument panel
near the center of the vehicle. The wire bundle consists of six
blunt cut wires, two red/white (battery hot), two black (ground),
one light green (Ign hot) and one light blue (Ign hot).
3. Remove the tape to release the wire bundles from the
power supply harness.
4. The IGN A and IGN B wires have voltage supplied and are
HOT when the ignition is turned to ACC, RUN or RAP
(Retained Accessory Power).
The BAT A and BAT B wires have direct voltage supplied
and are HOT at all times.
The combined electrical load of IGN A and BAT A must not
exceed 21 amps (250 watts). Additionally, the combined
electrical load of IGN B and BAT B must not exceed 21 amps
(250 watts). The combined electrical load of all circuits must not
exceed 42 amps (500 watts).
5. Prepare the wires that are to be used to connect the power
accessory. Do not remove the unused wires. Tape unused wires
back in their original position under the instrument panel.
6. Complete the wiring installation of the customer added
accessory with additional wire required for the specific
electrical accessory power connection. The wire gage,
12 gage (3.0 mm²), should be the same as the wiring of the
installed harness.
7. The ignition must be turned to OFF or ACC prior to attaching the
cables to the battery, or serious damage to the Vehicle Control
Module (VCM) may result.
The windshield wiper switch and the radio must be turned off
before attaching cables to the battery.
8. Reconnect the battery negative (-) cable to the battery. Torque
the bolt to 3.7 lb-ft. (5 N·m).
9. Reset the clock time and radio pushbuttons as desired
