24" Rims On A Silverado
citori man
Unless you plan on adding at least a 4/6 drop they will look like crap. Not to mention they are going to ride like crap either way.
ANYTHING bigger than 20's the truck needs to be lowered.
+1
cool looking rims though
  • 3 months later...
I got an 08 sierra with 24s on it and i put a 2 inch leveling kit on it. they are 305/35/24. I think it looks pretty good and it rides a lot better than i thought it would. Personally i dont like trucks that are lowered so I just leveled it. If I had it to do over i woulda got 26's. Im planning on lifting my truck so i can put 38 inch tires on the 24 inch wheels. Your original post was in september, did you put the rims on yet?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
