Drive Line
I have a 2008 2wd Silverado /at ,5.3 when I have it in 3rd when i take off I can feel like the drive line is lagging a little it will lag and then like catch .Any one have that same problem?
Also when I have it in drive and I'm at a stop light after awhile it feels like some one bumped into me.
Any one have that problem.
Thanks Doug
Thanks Doug
This has been a common issue for years....
Subject: Clunk Noise at Stop or from Launch (Clean/Lubricate Rear Propshaft Slip Yoke Splines)
Models: 2007-2009 Chevrolet Silverado 1500 Series
2008-2009 Chevrolet Avalanche, Suburban, Tahoe 1500 Series
2007-2009 GMC Sierra 1500 Series
2008-2009 GMC Yukon, Yukon XL 1500 Series
Equipped with 4WD (RPO NQG, NQH)
Attention: This contains a procedure to clean/lubricate the rear propshaft slip yoke splines and replace, if necessary. Check the history on this vehicle. If the lubrication procedure has been performed previously, then continue on and replace the transfer case rear output shaft.
Condition
Some customers may comment on a bump feel or clunk noise at a stop or on launch. Customers may also comment that the bump feel or clunk is noticed after the vehicle has come to a complete stop and that it feels as if the vehicle was bumped from behind.
Cause
This condition may be caused by a slip/stick condition between the rear propshaft slip yoke and the transfer case rear output shaft splines. Braking to a complete stop can force the propshaft slip yoke forward into the transfer case while the vehicle rebounds slightly backward after stopping its momentum.
Correction
Note: The clunk noise may also be due to fuel movement in the fuel tank when not completely full. If the condition is eliminated after filling the fuel tank, the noise is isolated to the fuel movement in the tank. Please make no repair attempts, as this noise is considered an operating characteristic.
Verify the customer's concern.
Clean/Lubricate Rear PropShaft Slip Yoke Splines
•Remove the rear drive shaft. Refer to One-Piece Propeller Shaft Replacement in SI.
•Inspect the rear propshaft slip yoke splines.
Note: Protect the transfer case rear seal from Brake Clean.
•Clean the rear propshaft slip yoke splines with Brake Clean or equivalent and a shop towel.
•Assure that the splines are free of rust or other foreign material.
•Lubricate the spline with Automatic Transmission Fluid, P/N 88861003 (in Canada, 88861004).
•Reinstall the rear drive shaft. Refer to One-Piece Propeller Shaft Replacement in SI.
•Road test the vehicle and verify that the noise is gone.
•If the vehicle has a repeat concern after lubricating the slip yoke splines, replace the rear output shaft.
Replace Transfer Case Rear Output Shaft
Note: Do Not replace the output shaft unless the cleaning and lubrication procedure is ineffective.
•Remove the transfer case assembly. Refer to Transfer Case Assembly Replacement in SI.
•Disassemble the transfer case. Refer to Transfer Case Disassemble in SI.
•Replace the transfer case rear output shaft. Refer to the Parts Information below.
•Assemble the transfer case.
•Reinstall the transfer case assembly.
Parts Information
Part Number
Description
Qty
19133059
SHAFT, TRFER CASE (RPO NQH)
SHAFT, TRFER CASE (RPO NQG)
This is the first time I've actually read the TSB, and have a question. I have read recommendations in numerous posts to "grease the slip yoke", but the TSB states to "clean and lubricate with transmission fluid". Did I misunderstand something?
No,You read it right,I actually didn't realize they want you to use tranny fluid either til I read this particle TSB,We always used a special slip yoke spline grease before.
WOW thanks I'm going to print this and bring it to the dealer again thankyou so much .Doug
  • 5 months later...
Well finally got it done last week after showing them the document they at first told me it was my lift kit I had to tell them to read the document that is the problem.Now it drives with no lag and no bump thanks again it's greatly appreciated.Doug
  • 5 months later...
Sorry for resurrecting an old thread, but would that service bulletin be covered under warranty? As I am experiencing this sensation of being hit from behind while stopped.
Im not sure how these bulletins work.. if its stuff that should be done for free or if the customer has to pay for the service. Im only at 80,000 km and my warranty is good till 160k
  • 4 weeks later...
Condition
Do you have the actual bulletin number for this? I need to show this to the service guy at the stealership i bought my truck from. he played dumb when I told him about a clunk when at a complete stop and only mentioned the well known launch/stop clunk
Theyre very eager to take my money.. but I'm not paying for something that should be free
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
