Zone 1.5" Body Lift
Just wondering whos running the Zone 1.5" Body lift and what they think of them. Did you do the rear bumper relocate? How long was the install time? Thanks
try posting in the right forum (suspension) might have better luck.
I have it on my truck and love it. I have the rear bumper kit also and would highly recommend it. Also the install took me about a day to do myself.
should i do the relocate with a 3" i just ordered? i never heard anything about a bumper relocate
the 3" comes with bumper relocation brackets...and YES you should install them.
Cool thanks. Should be here within the next week.
07blackz71 - do you have a large gap between the trailer hitch and the bumper with the relocate?
Not really. It still blends in with the bumper. THe 3" kit the hitch will be more noticeable.
You have any shots of the back of yours? Post em up, it'd be good to have a comparison.
Here's the 3" Kit:
^^ This is why I like the GMT900s... the hitch is so hidden from the factory that when you install a 3" body lift, it looks like a normal hitch.
Edit: Not even noticeable in the side view:
Which part of a BODY lift has to do with the suspension forum? :D
Here's the 3" Kit:
matt.. your right you can hardly tell you have the 3" body lift on there... I am still torn between adding the 1.5 and the 3" BL to the fabtech and going 35s vs 37s.. I would not be adding steps which is one reason I think the 1.5" will look better.. Another concern of min is the exhaust. What did you do about yours?
I cut my exhaust off after the muffler, at the hanger under the bed. I like the "no exhaust" look... just cleaner IMO. Everyone has "exhaust" no need to show it off IMO :D
Here's a side shot of the body lift without the steps (i know i know, the frame sticker is still on it). I still think that even without steps these trucks hide the body lift easily. No one except one of us would know that frame showing meant it had a body lift... and driving down the street, you wouldn't know if it was a 1500 with a body lift or a stock 2500, unless of course you knew that the crew cab short beds were only 1500s... but you get the point.
It's a tough call. If i were you, id go 3"..... because if you don't you KNOW you're going to want that extra 1.5" soon after.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
