Differential Fill Plug . . .
pwsigmund
Project to replace the rusted out rear brake backing plates on my 02 Yukon hasn't started off too well. Has anyone experienced problems cracking loose the differential fill plug? I'm soaking it overnight in Kroil, but it wouldn't budge, even after wire brushing all of the rust off the outside. Kind of hate to take a torch under there considering the nearby gas tank and all. Haven't tried the drain plug yet.
Any suggestions or experiences would be appreciated!
The gas tank isn't that close. Heating it is one of the ways to get it off. If you got a torch I'd use it. Don't remove the drain plug or cover until you get the fill plug out
I disagree with txab,please do not do that ,if you have air and an air chisel ,get a flat bit for it and bark out the plug by digging in the edge and go lefty loosey ,comes out every time,
Thanks. I'll try that first, as I really don't feel realy comfortable underneath with a torch.
If all else fails, is there such a thing as an aftermarket cover with a fill port in it? I've got a drain plug on the bottom.
Check out the TA differential covers, they have drain/fill ports.
How long is the ratchet you're trying to use? Leverage is your friend :thumbs:
Put a pipe over the ratchet. as sk1er18 said leverage is amazing. Try some pb blaster on it.
Would you have a link??
I let Kroil (great penetrating oil) work on it overnight. I'll give a 1/2 breaker bar a try tomorrow with slow pressure. I initially tried a 1/2 impact gun reduced to 3/8, and the extension started to slip in the plug's socket, which worried me. I hope it will break free before the plug deforms. Maybe I should sacrifice a 3/8 extension and grind the end flat to get as much "bite" as possible. If it deforms before it breaks, then I'm stuck. . . .
I was able to get the plug out with a 18 inch breaker bar. The fill plug socket was so worn that the 3/8 extension's points were all that was diggin into the plug's socket flats. Not much more left to grab. But it was just enough to break it loose. When that plug finally started turning it was a great feeling!
Oil was black, and really seemed thinner than 75/90 weight. I guess it breaks down after 130K. Lot's of metallic shiny looking glop in the bottom and on the inner cover. Guess I should rinse some kerosene around in there. Took a lot of wire wheelin to get all of that thick rust layer off of the cover. What a mess.
All of the cover bolts had what looked like Loktite on the threads. Should I use thread sealant again after I clean them up, or just add some lock washers?
Any tips on getting the large pin out of the carrier, to free the axles?
Thanks for all of your help
Check this thread for some help.
    Clark_Elite
    Clark_Elite
  • Who's Online   4 Members, 0 Anonymous, 353 Guests (See full list)
