04SILVRADO Posted October 6, 2009 Posted October 6, 2009 Hello. I was wondering how to make the interior light stay on longer? When shutting the engine off and gathering my stuff to exit the vehicle. The light will go off in about 15 seconds. I would swear it use to stay on longer. I don't know if I accidentally adjusted to shut off quicker or not. Thanks for your help, Matt
Erichcb Posted October 6, 2009 Posted October 6, 2009 Look through your DIC and you should find were you can adjust the time
04SILVRADO Posted October 12, 2009 Author Posted October 12, 2009 Look through your DIC and you should find were you can adjust the time I did this and could not find the correct one to adjust. Does anyone know what the screen in the DIC I should be looking for? Thanx, Matt
Erichcb Posted October 12, 2009 Posted October 12, 2009 Look through your DIC and you should find were you can adjust the time I did this and could not find the correct one to adjust. Does anyone know what the screen in the DIC I should be looking for? Thanx, Matt might be under vehicle settings
Sir Dan Posted October 12, 2009 Posted October 12, 2009 The "exit lighting" adjustment is found under "feature settings" on the DIC. There are 30 sec. , 1 minute, and 2 minute settings but that may only apply to exterior lights. You could always just turn on the overhead with the pushbutton or crack open the door a bit to get the lights on... What is taking you so long to get out of the truck anyways??
04SILVRADO Posted October 12, 2009 Author Posted October 12, 2009 The "exit lighting" adjustment is found under "feature settings" on the DIC. There are 30 sec. , 1 minute, and 2 minute settings but that may only apply to exterior lights. You could always just turn on the overhead with the pushbutton or crack open the door a bit to get the lights on... What is taking you so long to get out of the truck anyways?? I'm handicapped....
txab Posted October 12, 2009 Posted October 12, 2009 Edit: Had to check the Owners Manual, Flyingbrian is correct in his post below, it's not adjustable. Only exterior lamps are adjustable
Flyingbrian Posted October 12, 2009 Posted October 12, 2009 It is on a fixed 20 second timer this cannot be changed in DIC
