Rounded Off The Trans Pan Drain Plug
Hi All,
I rounded off the drain plug on my transmission pan drain plug (2003 Yukon XL).
I've heard this is not an uncommon problem--apparently they overtighten them at the factory and then when you try to get them off, the bolt just rounds off? Well, whether it's true or not, both I and a friend of mine had the same experience, so we now need to use a bolt extractor to get it out of the pan.
I'm wondering if any others here have had experience with getting a frozen (and rounded off) transmission drain plug out, and if so, what extractor kit have you had the most success with? I see in the Tech wiki that we had someone who used a Craftsman kit for this, but I wasn't sure what particular kit he used. Sounds like it might be something like this?
http://www.brandsplace.com/0246-lt-4501.html
-Josh
hey josh,
ive had this same problem before. i slid underneath it with my mig torch and tacked an old china made wrench to the plug. just un-threaded it from there, and replaced the plug.
yup welding a wrench, or new nut on the old one is pretty much the easiest way.
A pair of needle nose vice grips may also do the trick.
For the most part extractors are extractors, use the middle size one so you can make a bigger hole if it strips out...and for the love of god don't brake the extractor off. They're not easy to drill.
I have a very good set of Snap-On extractors, you drill a hole and hammer them in, and its almost impossible to break them off...but the cost me like $175.
Welding isn't an option for me since I don't have a welder (of any type). I guess I'll go with an extractor.
oh another thing I have seen done.... if its accessible....is to file two flat spots on the old drain plug and use vice-grips or something similar.
Thanks to everyone for the suggestions. I'll start with the vice grips and go from there, and I'll report back how it goes getting the bolt out.
My friend has decided that he's just going to leave the drain bolt in place and drop the pan whenever he needs to get at the filter. If I have a terrible time getting the bolt out I may wind up going the same way :-) Hopefully not, though.
If he takes the pan off he can just bring it to a shop and get it removed than....and you could do the same....Just not at the same time so each of you have a ride to the shop :(:freak:
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
