2001 Yukon Xl 5.3l
grogman45459
When I had almost 94 K miles on my truck, I was 4700 miles between oil changes and I got the "check oil level" message on the DIC. I then took it to the dealer for an oil change and the guy working on it only said that it was 2 qts low and the problem could be the pcv valve acting up, but after pulling it out and shaking it, he heard the marble moving around and dismissed it as being the culprit. I got on-line and found a TSB(01-06-01029A) that called for a fixed orriface pcv, so I switched it out for the new one, right after the oil change.
Well, 4100 miles after that, yesterday, I check my oil level and see that it's dropped again, and appears to be almost 2 quarts low, no message on the dic though. Nothing on the driveway, engine and bay is clean - no blow back underneath that I can find, not seeing anything, anywhere. Exhaust is white colored on startup, and for the first few miles of driving. So I take it back for an oil change and the senior mechanic there is "almost sure" the problem is with the valve cover on the drivers side. He says they are prone to leaking, there's a TSB for it, and they are replacing the covers with a newly designed one under warranty on the newer models. He wants to replace it with part number 12570427 - says it's a new design.
Can I get your thoughts and are there any other tips that you can provide to help me narrow the problem down any further? Thank you, I sincerely appreciate your help.
I remember a fix for that as I recall to glue a dime with a hole drilled in it to the PCV valve ,
any other techs here can chime in on it ,maybe the valve cover came later
Ask him for the TSB number for the valve cover replacement.
After reading this post. I'd look into the possibility that along with wear, that maybe a poor quality oil might be part of the problem. Even it's being installed at a GM dealership, the oil may not be what you think it is. The quick oil change service can use whatever filter brand and oil brand they like.
Of course if the new covers fix you up then all is good.
Anyone have any additional thoughts? Man, I'd like to get this figured out..............
I would call a service manager and ask him,have a sit down with him ,if I used to do this fix ,alot of others have ,or get a cover and see the difference,do it man ,lol
I don't follow - ask the service manager to try to provide me with some certainty that this will fix the problem? Btw - I had a friend locally tell me to pull each of the plugs & inspect to see if any are oil fouled. That would tell us if it's internal, ie, the valve guide seal(s) or valve(s) or if it's something else.
Are you talking about putting this "dime with a hole in it" on the old style pcv? The new style that he has already installed has the smaller fixed orifice, I believe.
Yeah, I was thinking the same thing- you're correct, the new one has the smaller hole and it's basically an empty barrel, with nothing in it.
Does your engine look dirty and oily? I've got 76k on mine and still as clean as can be. I've never washed anything under the hood. I'd for sure be able to spot a 2 qt or even a 1 qt valve cover leak. Your plugs might not be as fouled as you'd think. 2 qts over 4100 miles, the plugs would be fairly clean. They might have deposits built up from burned oil, but I wouldn't think they would be soaking wet with oil.
You can take this for what it's worth. I haven't seen your engine. But if it were me, before I spent $250 for one valve cover replacement, I'd clean the engine around the valve covers and anywhere else I thought it might leak from. Then I'd keep my eye on things. I'd check my oil frequently and keep track of the rate of loss. You can add dye to the oil to help find leaks. You use a black light to pinpoint the area. I'd probably change brands of oil, That's what I do. You're there I'm not so you have to decide based on what you know.
So far my TSB searches haven't shown a valve cover TSB, but I don't have access to the TSBs on the newest trucks right now
I'm checking with someone to see if they have heard of this scenario.
When I had almost 94 K miles on my truck, I was 4700 miles between oil changes and ....2 qts low
The oil consumption spec for that engine is 1 quart or more in 2,000 miles is excessive. It looks like you are coming in under that spec. To be sure I would check it at the 2,000 mile mark.
On a side note I'm sure someone here (probably many here) will disagree with me on this but it is pretty accepted among technicians that the oil life monitor is going to give us engine rebuild buisness in the long run. What I mean by that is that we still change ours at 3,000 and that is what I suggest to my customers if you like your engine. Trust me I hate doing oil changes so I don't recommend it because I like to see your vehicle every 3 months, it's because I think that is what it takes. I have seen the oil life monitor cause alot of problems that would never have happened with the 3K oil change.
Mine is pretty clean as well and I did the spray and rinse with the Simply Green a few months ago, really just to get dust & dirt off of it, as the extent of oil that I saw was minor spillage. Really cleaned up. Good point with the plugs, but I did have them replaced with the wires at around 79K miles so they might show something. I plan on checking it more closely with this recent oil change.
Yeah, I looked around quite a bit for the TSB as well, found nothing.
Thanks - on the OLM, I really just started using it in the last year or so and if for nothing else but cheap insurance, I think I'll just go back to the 3month/3K mile school, especially since I haven't figured this out yet.
I run full synthetic in my engine, and I still change it every 3K with a new filter every time.
I get damn near the full 6 quarts back when I drain the engine too.
If you checked your oil yesterday, and you seen oil on your dipstick there is no way its 2 quarts low....the add mark is add 1 quart...anything below that is not visible on the stick. If there's oil between the hash marked area, than its in the normal operating zone.
So maybe I'm not as bad off as i was told - when it was low, the oil level was at the first punched circle on the dipstick............and that's were it was at between the second change as well(4700 miles first, then 4100 miles). I'll grab the book and look closer...............thanks
So the whole time the lowest it has ever been is 1 qt over 4100-4700 miles? Quit worrying then
    • When I bought my 14 GMC I turned it off with an handheld programmer. With my 16 Odyssey I left it on solely because I didn’t have much money in the vehicle. There’s a device to turn it off that’s a little more involved. The GMC at 72 MPH the deactivation was on very little the deference was 1/2 mile per gallon. The Odyssey is on over half the time at 72 mph.
    • Anyone ever thought about switching the interior door panels from the base model to the Denali style? I’ve seen that you basically have to cut, sand, mold, paint, the window switches together to get the look right. Is that the main reason people don’t bother doing the swap? Seems like the only method that is easy I guess, without having to mess around with wiring and stuff.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
