New Recall Out
#09184: Customer Satisfaction - Material Over Sensing and Diagnostic Module Retaining Moisture - (Oct 20, 2009)
Subject: 09184 -- Material Over Sensing and Diagnostic Module Retaining Moisture
Models: 2007-2009 Chevrolet Silverado
2007-2009 GMC Sierra
Currently or Previously Registered in Connecticut, Delaware, District of Columbia, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, , West Virginia, Wisconsin
Condition
Certain 2007-2009 model year Chevrolet Silverado and GMC Sierra vehicles currently or previously registered in Connecticut, Delaware, District of Columbia, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, and Wisconsin may have a condition where an electronic component located beneath the driver's seat may corrode due to a significant quantity of snow and/or water containing road salt or other contaminants entering the vehicle and saturating the acoustical padding beneath the carpet. The vehicle's electronic sensing and diagnostic module (SDM) is located underneath this acoustical padding. If sufficient moisture collects and is retained in the padding, it may cause excessive corrosion under the module; compromising the module seal and allowing water intrusion and system malfunction. This may result in illumination of the Airbag Readiness light, along with a "Service Airbag" message on the Driver Information Center, and in rare cases, deployment of the seat belt pretensioner and/or airbags.
Correction
Dealers are to remove the acoustical pad above the SDM.
Vehicles Involved
Involved are certain 2007-2009 model year Chevrolet Silverado and GMC Sierra vehicles currently or previously registered in Connecticut, Delaware, District of Columbia, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, and Wisconsin, and built within these VIN breakpoints:
Year
Division
Model
From
Through
2007
Chevrolet
Silverado
71500002
71734671
7E500001
7E604245
7F500002
7F567567
7G500016
7G557689
7Z500001
7Z653672
2008
Chevrolet
Silverado
81100005
81340478
8E100001
8E218327
8F100001
8F228336
8G100044
8G315222
8Z100001
8Z333466
2009
Chevrolet
Silverado
91100005
91141878
9E100001
9E159067
9F100005
9F178564
9G100026
9G266868
9Z100001
9Z280992
2007
GMC
Sierra
71500001
71734578
7E500003
7E604243
7F500004
7F567377
7G500017
7G557568
7Z500002
7Z653614
2008
GMC
Sierra
81100007
81340465
8E100002
8E218285
8F100002
8F228333
8G100047
8G315264
8Z100003
8Z901791
2009
GMC
Sierra
91100004
91140535
9E100003
9E159061
9F100002
9F178559
9G100029
9G266866
9Z100010
9Z279538
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using GMVIS (dealers using WINS) or the Investigate Vehicle History screen (dealers using GWM). Not all vehicles within the above breakpoints may be involved.
For dealers with involved vehicles, a listing with involved vehicles containing the complete vehicle identification number, customer name, and address information has been prepared and will be provided to dealers through the GM GlobalConnect Recall Reports. Dealers will not have a report available if they have no involved vehicles currently assigned.
The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this program is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Parts Information
No parts are required for this program.
Service Procedure
Note: Driver seat removal is NOT required for crew cab or extended cab vehicles. Certain 2009 regular cab vehicles built after approximately March 1, 2009 with carpet that has a 2-sided cutout over the SDM, however, will require driver seat removal. Refer to Front Seat Replacement-Bucket in SI. After the seat removal, proceed to Step 2 in the bulletin. Regular cab vehicles with carpet that has a 3-sided cut over the SDM do NOT require seat removal.
Move the driver's seat to the full forward or rearward position.
Carpet and cutout flap shown with the driver's seat removed from the vehicle for illustration purposes only. Seat removal is NOT required to gain access to the acoustical pad.
Lift the cutout flap in the carpet or vinyl to gain access to the acoustical pad that covers the SDM.
Seat removed for illustration purposes only.
Using your hand, tear away and remove the acoustical pad that covers the SDM. Ensure that no acoustical pad remains over, or in contact with, the SDM.
Lower the carpet or vinyl cutout flap over SDM and adjust the driver's seat to the customer-desired position.
Courtesy Transportation
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranties. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product program is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
Claim Information
1. Submit a claim using the table below.
2. Courtesy Transportation - For dealers using WINS, submit using normal labor code; for dealers using GWM - submit as Net Item under the repair labor code.
Labor Operation
Description
Labor Time
V2133
Remove Acoustical Pad from SDM Area
0.2
Add: Seat Removal (Regular Cab with 2-Sided Cutout Only) (Vehicles Built after approximately March 1, 2009)
0.3
Customer Notification
General Motors will notify customers of this program on their vehicle (see copy of customer letter included with this bulletin).
Dealer Program Responsibility
All unsold new vehicles in dealers' possession and subject to this program must be held and inspected/repaired per the service procedure of this program bulletin before customers take possession of these vehicles.
Dealers are to service all vehicles subject to this program at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Program follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this program enters your vehicle inventory, or is in your dealership for service in the future, you must take the steps necessary to be sure the program correction has been made before selling or releasing the vehicle.
October 2009
Dear General Motors Customer:
We have learned that your 2007, 2008, or 2009 model year Chevrolet Silverado or GMC Sierra, currently or previously registered in Connecticut, Delaware, District of Columbia, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, and Wisconsin may have a condition where an electronic component located beneath the driver's seat may corrode due to a significant quantity of snow and/or water containing road salt or other contaminants entering the vehicle and saturating the acoustical padding beneath the carpet. Your vehicle's electronic sensing and diagnostic module (SDM) is located underneath this acoustical padding. If sufficient moisture collects and is retained in the padding, it may cause excessive corrosion under the module; compromising the module seal and allowing water intrusion and system malfunction. This may result in illumination of the Airbag Readiness light, along with a "Service Airbag" message on the Driver Information Center, and in rare cases, deployment of the seat belt pretensioner and/or airbags.
Your satisfaction with your 2007, 2008, or 2009 model year Chevrolet Silverado or GMC Sierra is very important to us, so we are announcing a program to prevent this condition.
What We Will Do: Your GM dealer will remove the acoustical padding above the SDM. This service will be performed for you at no charge .
What You Should Do: To limit any possible inconvenience, we recommend that you contact your dealer as soon as possible to schedule an appointment for this repair.
If you have any questions or need any assistance, just contact your dealer or the appropriate Customer Assistance Center at the number listed below.
Division
Number
Text Telephones (TTY)
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1-866-996-9463
1-800-462-8583
Courtesy Transportation: If your vehicle is within the New Vehicle Limited Warranty, your dealer may provide you with shuttle service or some other form of courtesy transportation while your vehicle is at the dealership for this repair. Please refer to your Owner’s Manual and your dealer for details on Courtesy Transportation.
We sincerely regret any inconvenience or concern that this situation may cause you. We want you to know that we will do our best, throughout your ownership experience, to ensure that your GM vehicle provides you many miles of enjoyable driving.
Scott Lawson
Director,
Customer and Relationship Services
so I just bought my 2008 GMC Sierra 2500 HD SLE 4X4 2 months ago from a GM dealership, got the notice about this recall in the mail 1 month ago and had it back to the dealershipimmediately to be rectified. Friday night my Service Airbag light came on and then Saturday morning when I hit the unlock button on my key fob, the airbag in the steering wheel deployed!
To my understanding, GM should be responsible for this, correct?
Andy
MAN!! That had to startle the living daylights out of you. Man, thank heavens you weren't driving. That could have been awful.
Dropped off my truck Tue night to get the heated washer fluid fixed. Just picked it up a couple of hours ago. Not only did they replace the heating unit they performed work on a new recall that came out on the 19th. I could not get a lot of details because nobody was there who knew anything, sounds typical of a service department,. It has something to do with removing insulation in the engine compartment. The number is 09184. This is a recall and not a TSB.
Wait,...wait. They replaced the heating unit? I thought they just removed them.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 607 Guests (See full list)
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
