Not the steering column switch or harness. Check them visibly and with continuity light. Tell me more about the brake pedal switch. Is it part of the stop light switch or a separate device? When I push on the tow haul button the indicator on the cluster is on but it has no effect on the transmission. Loaded or unloaded at any speed. It hasn't worked since I got the truck. The dealer said it is just fine. Quote .."It is operating within the parameters set by GM for that truck that year" I have driven other 09 Silverado's and they work just fine. Mine is a 1500 WT 4.8. Did GM tamper with them in an effort to raise fleet mileage numbers or for some other reason. If so what can be done? I bought this truck to tow an RV so the tow haul is important. Thanks..Ziffel
Real world mileage doesn't matter to GM. For what it's worth, tow/haul is much less obvious in my 2011 than my 2003 was.
Thanks, Do you know if the sensitivity of the Tow Haul can be adjusted up and down and how is it done. Is it something I can Do? I am used to my 99 Silverado. It works very well. This one has never worked. Thanks Ziffel
Got truck back from dealer. After extensive testing and a call or two to GM Engineering it has been decided that there isn't anything wrong with my truck. On the way from a dead stop using moderate throttle and with tow haul activated the 4L60E shifted thru all four gears and locked the converter. Doesn't seem right. Also noticed the converter doesn't unlock when tapping brake pedal. All fuses are good and the brake lights work. I was unable to find anything about it in the owners manual. My 99 does but I don't know if this 09 should. Thanks..Arnie
09 Silverado WT 4.8 4L60E manual transfer case. 3.42 gears and 18" tires. 66K
I thought that T/H locks out 4th gear?
It does not. It avoids 4th unless conditions are right
If the steering column wires are the problem; it also could be your brake pedal switch as well. They have been known to give out from time to time.
Totally disregard this post, I was thinking cruise control...brake light switch and tow/haul have nothing to do with each other...my apologies.
Doesn't stepping on the brake pedal unlock the convertor?
yes but its not as obvious like ear;ier yrs where ya can see the 200 rpm jump ....its PWM now and that means its ramped up and ya dont feel it ,,,,
somebody needs to post a description and operation for the tow/haul system,,,i cant right now
Evan if I can not feel the convertor unlocking, it should show on the tach. Also if I apply throttle should the RPM'''s rise until it relocks? Thanks Arnie
My tow/haul light on dash comes on in park but after you put it in gear you can't shut it off or turn it on.
Weird. My '04 Sierra 3500 can switch on the fly, even at highway speed. And it actually switches gear, turning it on will generally make it downshift unless I'm going downhill, and then turning it off will shift back, at highway speeds.
Used to work the same as yours davester. If you put it in gear the light will not come on. Going to take the steering column apart tomorrow and see if the orange wire is broke. But if the wire is broke why does the light come on in park?
Thanks to everyone for your input. I've seen the orange wire broke in half before. Now I've heard the two wires in the orange insulation can actually be broken with no visually way to detect the break. So I am going to put the multi meter on it and check the leads to see what the continuity is and the resistance. I also have one more problem. My direction/temperature readout on my rearview mirror is not working. Everyone had great input on the tow/haul problem and made my life much easier. Hopefully someone has ran into my second problem also. Thanks to all of you.
I just bought a 06 Sierra and compared to other Chevy trucks I have owned with tow/haul option it seems odd the way it works. I thought at first it did not work at all, I would push it and indicator light would come on but nothing would happen ! Then I discovered it would only lock up at speeds of 50 mph or below and would automatically shift out at 58-59 mph on it own !
I had it in the Chevy dealer for a follow up on another subject and described it to the service writer, they drove it and said it worked correctly and they could not find a service adviser on tow/haul problems. And here I have read several different problems on them!
Can anyone tell me if the way mine works is correct or not !? I have had vehicles with tow/haul and they all pretty much engaged and stayed engaged until you would turn it off.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
