Aftermarket
I am looking to build a 4.8L for turbo application.
I cant find anything in the usual places (Jegs or Summit) for rotating assembly. Looking for forged crank H/I beam rods and forged or hyper pistons.
I know I can probably get away with stock internals up to about 14psi, but I may want to go higher. So I would like to have the parts in there just in case.
Drop me some links if you guys know any...Thanks.
I am looking to build a 4.8L (will be a 5.4L) for turbo application.
I'm certainly not an expert on small-block gm motors (more of a Ford engine builder) ...but it seems to me the 4.8L probably gets left out of the "mainstream" when it comes to cranks/rods/pistons and the like. Probably would be better to use the 5.3L block tor a build like that. Seems to be alot more available for the 5.3L ...maybe even the 6.0??
well the plan is to use a 5.3 Aluminum block, and 4.8L rotating assembly with dish pistons...want an 8-8.5:1 CR
the pistons are the same in both engines its only the crank and rods that make a 5.3 what it is. Its only a few mm in difference in stroke.
But I want the shorter stroke so it revs better.
Problem is I cant find pistons or anything for a 5.3 or 6.0L either.
I did find a 427 stroker kit on SLP's website, but its a high comp kit. I dont know if I could get some Low CR pistons...cause a 7.0L turbo would be hella cool.
What about a 383 Stroker? That seems to be an extremely popular GM performance motor. I would think there would be a pretty versitile line-up of pistons/cranks/cams for that block. I'd imagine that 383 could be a pretty sweet revver on boost!
Want to stay with the LS-style engine.
I really haven't seen anyone build a 6.3L LS motor yet...so I doubt there is anything available for a 383 LS
You would think that with the amount of these LS engines on the road...for the last 10-12 years, you would think they would have an aftermarket like a SBC. The 5.7L has a tonne of parts...too bad they stopped making it in like 02.
I know the stuff is out there...there have been loads of people build truck engines in the magazines.
So I found out that the LS blocks are all pretty much the same, and the truck engines can be bored out to accept 5.7L pistons...or 6.0L pistons
Even as far as making a 427 (7.0L) out of a 4.8L is possible.
There is a lot of options open now.
So I will probably build an iron block 5.7L.
Now I need 3 things;
Time, used engine block, and most importantly....Time
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
