A Myriad Of Trans Q's.
A few months back, I was accelerating on an onramp from one highway to another and I noticed a metallic grinding sound. I immediately pulled over, and based on the sound, guessed that something might have happened to a brake rotor. One by one, I jacked the wheels up and spun them with all my manual might, but I couldn't reproduce the sound. Having had the transmission rebuilt once already at about 65,000 miles, I feared the worst and had the truck towed home. I did more diagnosing at home by pushing my truck around the parking lot and seeing what conditions reproduced the noise. Huge waste of time and energy, however, as I don't know anything about trucks or automatic transmissions, but the bet was on u-joints. I got the number of a trusted mechanic about a mile from home and drove my truck there. His prognosis was that the planetary gears in first gear are failing (my previous transmission suffered the same fate at 65,000 miles). He came to this conclusion based that the sound went away as soon as the truck shifted into second gear.
The mechanic offered to rebuild the transmission for about $1,600, but not having the money I declined. I just shifted into second gear and started off from there. I rarely drive my truck as my primary transportation is my Harley, so I wasn't overly concerned. Not too long ago, however, I only got about a block from home when my engine was cranking out rpm's, and not turning the wheels (as luck would have it, I had already crossed the intersection). Now you have the facts, here are my questions.
My first transmission failed at around 65,000 miles, and then at 122,000 miles, establishing a grim 65,000 mile interval. Is the planetary gear failure coming from another culprit, or is my powertrain just consistently unlucky? Both times, failure was sudden, much more so the first time. The first failure ended catastrophically on a highway miles outside of town, grinding violently and horribly. This time, like I said, it was a smooth grind, like a brake rotor dragging lightly (if you could hear that through the cab), ultimately ending in a slipping transmission. Now that the transmission isn't transferring power, there is no noticeable grinding.
Is the transmission slipping now because of the clutch somehow failing from all the second gear starts? Again, I don't hear any grinding coming from the transmission at all. The motor just performs beautifully.
Many transmission rebuilders in town have bad reports online. It begs the question, is rebuilding ever worthwhile or should I buy a new transmission? I started shopping on Summit Racing and eventually found an appealing match on GM Performance Parts: Part# 19156259 4L60E 4-speed automatic transmission. On that note, I'm driving a 2002 GMC Sierra 1500, extended cab, 6'6" fleetside bed, 2WD. So how can I tell if the Gen III/IV transmission will work for me, or will I need the Gen I/II conversion? Here's a link to the site where I found the prospect. It's the only 4L60E on the page; the rest are 65, 85, etc. Lastly for transmissions, will a new transmission be all I need or will I need a new torque converter, too? I don't even fully understand how the torque converter does what it does… or exactly what it does, for that matter. I just know a local shop here requires a new one in order to get a warranty on their work.
My next question concerns Tow/Haul mode, and transmission coolers. I think my truck originally had a hitch receiver on it, but it didn't when I bought it, used with 36,000 miles. I bought a GM weight distributing hitch online, and expect to do some towing in the future (the occasional move, and hopefully one day hauling bikes to/from tracks). A friend suggested that if the truck has a Tow/Haul mode button in the shifter (and lights up in the dash), that my truck has a transmission cooler already. Looking at the radiator, I see what appears to be a smaller radiator, low and in front of the engine's radiator. Is that an oil cooler or do I have a transmission cooler?
This was my first vehicle, and I'm extremely reluctant to give up on it. This truck and I have been through a whole hell of a lot together. I have over 122,000 miles on it, and I wouldn't mind taking it to 300,000 miles, but not if I have to replace the transmission every 65,000 miles! I appreciate any input y'all have.
Ok...that is a lot of questions.
I would buy a GM replacement trans...as it has a 3 year warranty...and yes you have to buy a new torque converter.
The replacement trans is not that much more than the rebuild.
you have a gen III LS Style engine in your truck, provided you have a V8. Even if you have the V6...you still have the Gen III style trans.
The 4L60E trans is one of the most abundant transmissions out there. Pretty much everything that's auto and RWD/4X4 from GM has one...until you get into the 3/4 tonne realm and larger. But I haven't heard of them failing every 65K miles. They're not the greatest trans on the market, but they're stronger than that.
BTW...so you know....just because your shifter is in 2nd, doesn't mean your trans is in 2nd...it doesn't work like that...it will only shift up to 2nd...and if you rev it out far enough...it will still go to 3rd, that's a safety feature. What you lost as you crossed the intersection was the last remnant of your 1st gear...or maybe more of them, depending on your speed and RPM at the time.
The Tow/haul button is on all Auto Silverado's from 99 up....maybe before that. This doesn't mean you have a trans cooler...the small rad you see up front could be a "rad" for the power steering, depends on what lines are going into it...you have to follow them back.
the small radiator is for the tranny...look for z85 in the rpo codes in the glove box, thats for the heavy duty trailering package, which comes with a cooler and a hitch stock....the majority of people will say rebuild, me, i'd just buy a new one with a warranty....those trannys are russian roulette some go 20k some go 300k its just hit and miss, the main problem i've heard that goes out is the main planatary gear, most people rebuild with something called the beast...idk just get a new one from gm (**** the 60 go for the 65, it takes a bigger beating) or overhaul up to the 80, yes it bolts up.
Depends...I have a trans cooler...but it didn't come with the trailer hitch. Or even wired for one. Its trailer hitch ready...and wired to the bumper, but the hitch and harness is dealer installed...or so I was told. I know its never had a hitch on it.
sorry ,the GM rebuilt tranny has a torque converter with it ,the tech will also flush the factory cooler and check the flow rate thru the cooler for warranty pruposes,and the 3yr warranty they come with ,I bought one before I left the dealer ,cost +10%,smokin deal
Cool didnt know they came with the TC...that's an even better deal than...hell even if you have to pay full price for it..Its still worth it.
3 year warranty, complete with a TC and they flush all your lines and cooler...Sorry....But you'd be a Moron not to do this.
Whats the price for a fully installed replacement Rob...for someone that has to pay full price?
Thanks for the quick response, gents. Sorry I forgot to mention I have the 5.3 L V8. You're certain 60 and 65 transmissions are interchangeable? Is it more reliable than the 60? My suspension is set up for 1/2 ton towing, and it's unlikely I'll change that because of how comfortable the ride is right now. So, would the 65 be a worthwhile investment?
65 is basically the same trans as the 60 nut with a 5 pinion planetary set and stronger sun shell.
Basically its the factory upgraded 60
All the trans will interchange...even the 4L80E its just a matter of changing a few things...
Your best bet though is to go with a 65...you don't need any modifications to make it fit than.
Great, I want one, then. Any ideas about consistently breaking down at 65,000 miles?
Karma???
Are you a heavy right footer? Do you engine brake a lot, (dropping it in a lower gear to slow down) cause that's not good for your trans.
Do stupid things like neutral drops, or brake burnouts?
If not you just have bad Karma.
Karma???
Ha, I lead a pretty good life, I think! I'm just worried that something's out of alignment.
July 08
'93 4l60E retails CDN $ 2475 without core charges,I paid $2001. ,
plus the taps cells should be cleared so the adaptive process can start again
sorry ,labour for a 4WD generally is gonna be 7.5 hrs to flip it ,includes the flush of cooler and scanner time
DO NOT QUOTE ME ON THIS ONE PLEASE ,but its close ya know lol
any diag will be extra,but if ya go in and say order me a SRTA and put it in ,then thats it plus oil and t- case gasket
I would as a customer want to see the labour in the book,being aware of any add ons if applicable
