Real or Fake???
Torque Junkie
Real or Fake???
1 member has voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
when i first seen the topic i thought it was for real or fake boobs haha
:D
fake: tree
real: you know  :D
real/fake, who cars as long as they look good.
Yes, I'm talking about trees, geez, I mean, I know Ryan's mind is in the gutter.
We've got a fake tree at home.  No needles everywhere and I think my mom is allergic to pine trees or something like that.  I don't know, it's not my house and not my tree.
Fake trees are safer, and look better, while real trees smell so good, and have that natural appeal to them.
I like 'em both, as long as presents with my name are underneath it :D
-Mike
Posted on Dec. 19 2001,1:24
fake: tree
real: you know
Same here Ryan. :D  ;)
MIND IN THE GUTTER?
hey what can i say i
:love:
em
For some reason Britney Spears came to mind when I saw this topic :D
We have a fake tree at my house. We had a real tree one year. Spent most of the time trying to keep it standing. Didnt work, it fell a few times.
Our tree is fake, but about once every 3 years or so we get a real one.
for you gutter boys, fake is better than nothing at all...  ;)  ;)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
