Fog Light Installation Help
i want to add fogs to my 2000 silverado and was wondering if it is possible to use the trailer parking lamp fuse with the fogs so that the switch can control them. Will this cause any problems if i were to do this and have my fogs on when i tow my small atv trailer or will this cause the fuse to blow. Any suggestions would be great. Thanks
Brandon
Brandon
Why not just use the Fog Lamp fuse?????? Add on a circuit????? Just me but I would not splice it in...... use a relay and you can pig tail from the low wire on one side back to the circuit trigger on your relay for your fogs with diode and have them on anytime your lows are on. Pull the fuse box off and you will have 2 studs that are hot all the time.....
Jbo
Jbo
+1
