so tell us the difference in feel between the 6.0 vs 6.6.
Haven't hauled in any hills yet but the 6.6 barely knows it has a trailer attached. As designed, the 6.0 obviously revved higher but it did the job just fine. The 6.6 just does it without much effort
Sent from my SM-G920W8 using Tapatalk
curious how the feel would be with any wind or getting passed by a truck, etc. if it would move one over the other any more/less
I haven't had the 6.6 in wind yet, but the 6.0 did not move at all when passing a tractor trailer and it took a lot of wind to move the trailer side to side. The 6.0 sucked gas with a headwind though.
I imagine the diesel will handle the same. The difference in a travel trailer to a fifth wheel is night and day for ease of towing IMO
Im still trying to decide on the next rig. If I want to go gas or diesel. Gas will do what I need. Diesel would be overkill but also piece of mind.
That's why i made the move
If you can swing it, the diesel makes it all so much less stressful. The constant shifting and high revving of the gas motor drove me nuts. The diesel and Allison is a no fuss way to get the job done. I pull a TT that's about 9500# loaded, and although it's not as brisk as when not towing, the truck feels as though it barely knows it's there.
I use mine so little for towing that I often debate it's worth, but each time I tow my TT or utility trailer I'm reminded and it tides me over till next time.
Pin is 1950 wet
If it's a 2500 doesn't that only give you like 300# of capacity remaining?
150 lol
150 lol
OMG. Hope you and yours are itty bitty.
Load more crap in the back of the trailer. [emoji1]
3500 inventory was limited !
I understand. That is an issue, especially if you want SRW, which I did too. And I heard they didn't do the midnight package on the 3500's. Not sure how true that is.
I saw one but they give you Michelin tires and not duratrac
Unless the 3500 midnight was a short ru n
I would have loved that option. I had the dealer swap the duratracs for Michelins after two weeks. They were too loud for daily use.
That being said, the duratracs are admittedly much sexier. Ended up swapping the midnight wheels for 20" 5 spoke GM wheels in brushed alloy anyway.
I had duratrac tires added to those wheels on my last Hd
Loved the look
Time for a week in the mountains.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
