4wd Noise
truck has just over 10k miles on it. This the 2nd winter for this truck and I noticed a grinding noise which appears to be coming from the transfer case. Its not the normal sound you get while in 4WD. I had this truck in the snow last year. Also this is my 5th 4WD gm truck i've owned so i'm familiar with all the normal howling/ grinding, etc noises. Oddly enough i get a similiar noise when applying brake (no it is not abs sound). All this happens while city driving on snow/ice roads. Noise does go up w/ engine rpm. Anyone experience this - or am i just going crazy. By the way, it is 4.8litre w/ on the floor 4wd shift.
something with the shaft from the transfer case to the front end? does that shaft have joint in it? i can remember off the top of my head
There are u-joints, but it's still just a one piece driveshaft.
Since it's a manual shifting transfer case, I have to wonder if maybe the lever isn't engaging the t-case all the way or just isn't locking into position properly.
Does the noise happen in both 4HI AND 4LO, or just 4HI?
I haven't tried in 4LO yet. 4wd works fine so I'm just going to run it and bring it in after winter. Unless the noise gets worse.
Its obviously coming from the muffler bearing....
If you want a better diagnosis....bring it in to the dealership where they honor this wonderful thing called a warranty...you take the service manager or mechanic out for a drive and let them hear the noise...than they look at what they think it is and come back to you telling you it was a wappaty splash that was stuck in the metrickulator and your on your way...no guessing...no bad advice and best of all...no money out of your pocket.
:uhoh: What kind of mentality is that? You don't know what the problem is, it could be causing further damage by just 'running it' as is.
:eek: What kind of mentality is that? You don't know what the problem is, it could be causing further damage by just 'running it' as is.
Mentality of someone who needs his truck to get to work in the winter but does not have time to mess w/ the dealership. I understand it is under warranty and I'm sure GM will honor it. I just thought I would post to get some thoughts on how serious it is. Also, if you read the thread there is not an issue while in 2WD.
I do agree that it needs to go to the dealership. Hopefully soon... perhaps I can get the those 'muffler bearings' serviced!
Just cause you cant hear anything going on in 2wd doesn't mean nothing is getting damaged in 2wd. If you absolutely need a vehicle, and you kick up enough stink at the dealership...they will get you one.
    Zinister101
    Zinister101
  • Who's Online   3 Members, 0 Anonymous, 683 Guests (See full list)
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
