Tire Pressure Sensors
Marty1234567
Hello, I have a new 2009 Sierra SLT.
The flat light and "check tire pressure" alarm go off after driving 20 minutes.
I have had it into the dealership 5 times and they changed the sensor in the tire and the rcdlr module. they updated the software in the truck and they have up dated the hand reprogramming device, T2. They have given up and say it's probably my after market amp the sub woofer causing problem. I like the truck but it seems there is no way to fix this.
Is there a way to just turn the system off so the truck will not look at the tire pressure?
How do you do it? I have a friend at the dealer who will do it if someone can tell us how.
Thank you.
Would require access to the programming code of the BCM, which you probably won't get, as it's a federally mandated item.
Thanks, I have access to the equipment, just not sure how to do it. The mandated requires the truck to be sold with the system but I don't have to keep it.
That sucks -- another fine brainchild of the federal government. :cool:
This has got to be one of the dumbest systems I have ever seen installed in a vehicle. It would be one thing if it was just for convenience, but to flash lights in your face is just moronic.
What's next? A federally mandated light reminding us to breathe??? :D
Sorry I was no help ...... just venting .....
Have they checked the spare tires sensor?? Sometimes it gets forgotten.
How long would it take you to disconnect the amp etc..just to prove its not whats wrong??
When did they start putting a sensor in the spare?
You may not have to keep it enabled, but disabling it would be difficult. If you have access to the source code for the programming in the BCM then you would have to go through all the lines of code and find the areas that pertain to the TPMS and remove all that code the recompile the code and flash it to the BCM. There is no real equipment that you need for that except the Tech II, what you need is the code that is locked away on some computer at GM.
2009.. I'd take the amp out and tell them to fix it or replace it! Thats just nuts they go blaming the amp for the issue dealing with the tires.
Sometimes dealer excuses really piss me off. :cool:
Since they started putting TMPS in.
if you swap to your spare tire and it goes flat...your still hooped...or like just about everyone...when was the last time you checked to make sure your spare had air in it....last time for me was when I had to use it.
Makes sense to have a sensor in there to let you know if your spare is gone flat.
I've put my OTC 3833 TPMS tool up to the spare tire and came up with nothing, I checked at the stem and 180 degrees from the stem.
There is no place on the DIC for spare pressure readout so a sensor does no good.
And I do check my spare, not as often as the regular tires, but I leave it at max cold pressure so I can put it on and lower it to the right pressure.
Weird...everyone I know with TPMS has a spare sensor....maybe its a Canadian thing. I know sometimes here it throws the techs for a loop cause they can never find the faulty sensor....than they remember the spare. I think the spare only comes up as a system fault though...where the other 4 come up as an individual position. Couldn't really tell you for sure...I don't have it.
Ah yes, the Canada vs US vehicle stuff. That might be the difference. Like we don't need DRLs and it's required in Canada, and yet for some reason we have them. Lucky for me there are fuses to protect the electronics, I'm using my fuse to protect the DRL circuitry from getting worn out. That's my story and I'm sticking to it.
the whole pressure reading system is dumb, even on the colorados if the tire drops 2 pounds it goes ballistic and throws a check engine light(on the colorado)...its nuts and dumb, it should of been an option to not have them...but thats they way things are moving sooner or later cars and trucks will tell you when to turn and when to itch your ass.
Thanks for all the imput guys.... If I do discover a way to disable it I will post it here.
There's no sensor on the spare here is the USA.
I think it's a great truck but the Tire Pressure monitoring system is a head of it's time as it's not robust enough for a truck.. people fix them up with different wheels and tires and change out stereo systems... For a lot of people that's half the fun of having a truck.
This system is to senitive really and has to be a lot tougher to be on a GMC if you ask me.
Pretty bad when the Technicians at the dealer can't enough figure it out......
Other than having to pull over and turn the key off and back on every twenty minutes so I can clear the alarm it's a great truck.... I only drive 17 minutes to work : )
there is no TPMS sensor in the spare Aiden
Hmmmm....could have sworn the techs down at the dealership was complaining about it one day...
Wow...maybe I was dreaming it....LOL
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
